MAJOR MODS...
225GUY
Well the banshee stoped shifting this weekend and we narrowed it down to where the clutch rod enters the case. Needless to say we had to pull the whole motor and split the cases. I found the rod broken, the ball bearing shredded, and the clutch plates burnt. Also I found the pistons had 9 thousands of clearance and the pistons burnt also. SO since I have the motor out, I figured I might as well do all I can for performance.
-New clutches
-Major cylinder head port work
-Milling the stock head
-Timing advance plate
-Boring cylinders out and new weisco pistons
-All new seals and gaskets
Any other suggestions? I was actually happy for this to break...:-) Now I get to mod it out lol
You should go ahead and put in a pancake bearing while your replacing your clutch rod and ball. Also check your clutch hub and pressure plate. They are only $20-$25 bucks to replace. Do you have a Pro Design billet impeller yet? What are you running for pipes? Have you picked a builder yet?
My advise is do some research on builders you can find many good ones on this .You can see from my sig who I chose.I like doing everything myself but just in parts knowledge alone its worth getting everything from one guy so everything meshes well.Im not going to turn this into a builder blowing war . Just dont jump into anything find the guy who catches your ear on the phone.Good luck !!!
it depends on what you want reliability or speed. for reliability id go with a long rod kit. trued and weld the crank. get the billet impeller. thats just a few and for speed you could get your cases port matched. reed spacers. i have 28 pwk's those are carb's by the way. work great. v-force 3 reeds. 15 tooth front sprocket. and for pistons allot of people get wiseco's and i mean allot of people. but it all depends on what you want to set your bike up for.
What does the billet impeller do for me and also what does the 15 tooth front sprocket do for me?
The stock water pump is plastic and can break, causing your shee to overheat and burn up. The billet is a thousand times stronger and is extra insurance. I'd suggest the Pro Design..
The 15 tooth will give you more top end speed and you won't have to shift as much, but you will be a bit slower accelerating.
