steeler2169 Posted February 14, 2009 Report Share Posted February 14, 2009 So ive just put on t-5, k&n filter 280 main and 27.5 pilot, screws out 1 and half out. It just doesnt have the pull it use to. Or maybe Im expecting more. Want i was looking for was the power wheelie when im on the road. Dont get me wrong its faster. I still have a gear to go at the end of the road to where i didnt use to. By the way im in Ohio elevation is 843.2. I dont want to buy more i just need some tips on tuning, I have 260 jets also if you think Im to rich Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted February 14, 2009 Report Share Posted February 14, 2009 whats your airbox and air filter setup, unless you have pods your piot is prob rich on the pilot? how does it run down low? what needle are u using and what clip is it on? how do the plugs look after running her hard with the 280 mains? how does it perform on the top end? Quote Link to comment Share on other sites More sharing options...
steeler2169 Posted February 14, 2009 Author Report Share Posted February 14, 2009 whats your airbox and air filter setup, unless you have pods your piot is prob rich on the pilot? how does it run down low? what needle are u using and what clip is it on? how do the plugs look after running her hard with the 280 mains? how does it perform on the top end? Air box is stock w/ holes in lid K&N filter,Top end isnt bad at all, Needle and clip in stock poss. Just just reminded me of that i didnt try them at all. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted February 14, 2009 Report Share Posted February 14, 2009 well id take the lid off, or cut a huge hole in it, i run pretty much the same elevation same pipes and filter but a huge hole cut through the lid both layers, 280 mains are great in the spring and summer weather on mine and a bit fatter for winter, with your lid right now though thats restricting alot of airflow if you keep it on you might try some 270 or 260 for the coming warm weather, i run the toomey needle, i run 3rd clip down from blunt end and stock pilot jet, throttle response is very crisp, your pilot must be rich, especially with that airbox and lid setup, put a stock pilot in it, and take the lid off or cut one big hole through the lid is what i like, some of the lid helps keep water out,and try it, u can read the plug chop thread too but some people will also say u can just look at the end of the electrode on the plug color after running it hard it should be a tan color and your main jets are good, gota play with it a bit and see what works, pilot def sounds rich though, and do somethin about the lid or lean it out a bit Quote Link to comment Share on other sites More sharing options...
steeler2169 Posted February 14, 2009 Author Report Share Posted February 14, 2009 well id take the lid off, or cut a huge hole in it, i run pretty much the same elevation same pipes and filter but a huge hole cut through the lid both layers, 280 mains are great in the spring and summer weather on mine and a bit fatter for winter, with your lid right now though thats restricting alot of airflow if you keep it on you might try some 270 or 260 for the coming warm weather, i run the toomey needle, i run 3rd clip down from blunt end and stock pilot jet, throttle response is very crisp, your pilot must be rich, especially with that airbox and lid setup, put a stock pilot in it, and take the lid off or cut one big hole through the lid is what i like, some of the lid helps keep water out,and try it, u can read the plug chop thread too but some people will also say u can just look at the end of the electrode on the plug color after running it hard it should be a tan color and your main jets are good, gota play with it a bit and see what works, pilot def sounds rich though, and do somethin about the lid or lean it out a bit Thanx ill try to fine the stock pilot. I put it in when i first got it becuase it had a dead spot down low but have not changed it since the pipes etc. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted February 14, 2009 Report Share Posted February 14, 2009 Perterd! :laugh: I think you meant perturbed hahaha Try taking the lid off and see what that does with the 280s. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted February 14, 2009 Report Share Posted February 14, 2009 Perterd! :laugh: I think you meant perturbed hahaha Try taking the lid off and see what that does with the 280s. LOL a little purr turd! HAHAHAHA. That made my day. Quote Link to comment Share on other sites More sharing options...
bode1 Posted February 15, 2009 Report Share Posted February 15, 2009 (edited) have you checked your compression, how fresh is your clutch? I had done some similar mods awhile ago and I didn't have the power I was expecting, turned out I needed a new clutch, got one and it was a night and day differene. Might turn out the extra power you added might be causing your clutch to slip Edited February 15, 2009 by bode1 Quote Link to comment Share on other sites More sharing options...
xXBlessedWithDeathXx Posted February 15, 2009 Report Share Posted February 15, 2009 Quote Link to comment Share on other sites More sharing options...
DopeyTripod Posted February 15, 2009 Report Share Posted February 15, 2009 JMO putting on pipes and the K&N's with diff. jets isnt gonna make yur shee come alive like yur thinking. best bang for your buck with a jaw dropping notice is going to be porting. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted February 15, 2009 Report Share Posted February 15, 2009 (edited) hahah douche - good one though goin from stock pipes to a new open filter setup and t5's should make a huge difference over stock Edited February 15, 2009 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
spurdy Posted February 15, 2009 Report Share Posted February 15, 2009 hahah douche - good one though goin from stock pipes to a new open filter setup and t5's should make a huge difference over stock True, but I thought he said at the end of the road he still had a gear left where he didn't before. He should be spinning up faster and hit top speed sooner, not later. He shouldn't have gained much top end, just whatever RPMs he has gained over the last set up. I'd bet his jetting isn't quite right. SP Quote Link to comment Share on other sites More sharing options...
