Corndiddly5885 Posted February 13, 2009 Report Share Posted February 13, 2009 I was wondering if i get +3+1 arms would +2 works shocks fit on there or no? Quote Link to comment Share on other sites More sharing options...
desertdeweller Posted February 13, 2009 Report Share Posted February 13, 2009 (edited) yes they will, the mounting points are the same. The only thing is since you changed your leverage ratio you might have to get them resprung or valved. Your best bet is to just try it out to see if you want to change them or not. you may find them to be to soft depending on how you ride, they also maybe fine for you. I did a similar change to mine before. I actually liked the ride better when I had the +3 arms on it with the shocks that were set up for the +2 Edited February 13, 2009 by desertdeweller Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 13, 2009 Author Report Share Posted February 13, 2009 yes they will, the mounting points are the same. The only thing is since you changed your leverage ratio you might have to get them resprung or valved. Your best bet is to just try it out to see if you want to change them or not. you may find them to be to soft depending on how you ride, they also maybe fine for you.I did a similar change to mine before. I actually liked the ride better when I had the +3 arms on it with the shocks that were set up for the +2 alot thanks i didnt know if they would fit cuz the shock is +2 and the arm only is +1 Quote Link to comment Share on other sites More sharing options...
MikeNick Posted February 13, 2009 Report Share Posted February 13, 2009 alot thanks i didnt know if they would fit cuz the shock is +2 and the arm only is +1 What the fuck are you talking about Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted February 14, 2009 Report Share Posted February 14, 2009 save your money and get elkas....i have had nothing but shitty luck with with works... they suck with customer service. ill respring and valve the yfz450 shocks before i buy from works or have them revalve my shocks. Quote Link to comment Share on other sites More sharing options...
2slow350 Posted February 15, 2009 Report Share Posted February 15, 2009 save your money and get elkas....i have had nothing but shitty luck with with works... they suck with customer service. ill respring and valve the yfz450 shocks before i buy from works or have them revalve my shocks. I agree, I like the elkas better.. Jmo Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 15, 2009 Author Report Share Posted February 15, 2009 I agree, I like the elkas better.. Jmo well i would get elkas but i want to get new a-arms and shocks at the same time and elkas just cost to much for me. well wats the cheapest pair of elkas? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted February 15, 2009 Report Share Posted February 15, 2009 Elka's Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 15, 2009 Author Report Share Posted February 15, 2009 Alright thanks. one more ? you its better to spent the extra money and get the piggybacks? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted February 15, 2009 Report Share Posted February 15, 2009 Alright thanks. one more ? you its better to spent the extra money and get the piggybacks? It depends on how hard you ride. The piggy help with the shock fading from heat. You can buy those elkas's I posted and then later if you think you need the piggy's you can add them later. Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 15, 2009 Author Report Share Posted February 15, 2009 It depends on how hard you ride. The piggy help with the shock fading from heat. You can buy those elkas's I posted and then later if you think you need the piggy's you can add them later. oh really thats good then. thanks alot for showing me them. so the heater it is, they will fade more then i am guessing? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted February 15, 2009 Report Share Posted February 15, 2009 oh really thats good then. thanks alot for showing me them. so the heater it is, they will fade more then i am guessing? Yea the more bumps you hit, And the more the oil compresses and uncompresses cause the oil to heat up and the shock to fade. The piggybacks hold more oil therefore are less likely to fade. Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 15, 2009 Author Report Share Posted February 15, 2009 Yea the more bumps you hit, And the more the oil compresses and uncompresses cause the oil to heat up and the shock to fade. The piggybacks hold more oil therefore are less likely to fade. alright. were can u buy them seperate? Quote Link to comment Share on other sites More sharing options...
BlntdEyez Posted February 15, 2009 Report Share Posted February 15, 2009 u would have to ship the shocks back to elka to have the piggybacks added. Its prolly better to just go ahead and get the piggybacks now Quote Link to comment Share on other sites More sharing options...
Corndiddly5885 Posted February 16, 2009 Author Report Share Posted February 16, 2009 So it would be cheaper just to get them right away? Do u know how much it cost to get them added on later on? Quote Link to comment Share on other sites More sharing options...
