NOS_350x Posted February 13, 2009 Report Share Posted February 13, 2009 I got a set of cylinders given to me from my banshee as spares. The bottom of the sleve is broke off on one cylinder. i was wondering if anyone has tryed to press in and out one. I think i could do it. Also wondering if somone has a sleve or set laying around. Dont want to kick down with the $ if the porting sucks. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted February 13, 2009 Report Share Posted February 13, 2009 All of the replacement sleeves that I know of are larger OD than the stock ones and require machine work to install. Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted February 13, 2009 Report Share Posted February 13, 2009 i remeber seeing 64mm sleeves. brand new for 80$ for both... meh (on ebay) Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted February 14, 2009 Report Share Posted February 14, 2009 I believe you have to bore the old sleeve out since yamaha casts the cylinder around the iron sleeve. Quote Link to comment Share on other sites More sharing options...
FireHead Posted February 14, 2009 Report Share Posted February 14, 2009 I believe you have to bore the old sleeve out since yamaha casts the cylinder around the iron sleeve. You can heat up the cylinder and press the sleeve out, but it more trouble that a set of eBay cylinders is worth. :geek: Quote Link to comment Share on other sites More sharing options...
