98_BANSHEE 93 Posted February 11, 2009 Report Share Posted February 11, 2009 OK LOOK go to the place that sells yamalube ...get the pint size bottle and a five gallon gas can ...dump the yamalube in ...then fill the rest with gas and shake up ....FANTASTIC MIX !!!!!!! Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted February 11, 2009 Report Share Posted February 11, 2009 OK LOOK go to the place that sells yamalube ...get the pint size bottle and a five gallon gas can ...dump the yamalube in ...then fill the rest with gas and shake up ....FANTASTIC MIX !!!!!!! the scientific method Quote Link to comment Share on other sites More sharing options...
mignumspeed Posted February 11, 2009 Author Report Share Posted February 11, 2009 40:1 castor. There are hundreds of posts on this if you do a search. And you jetting sounds way low for a piped banshee. How do you plugs look? Did you mean 310? 220 is stock. ive just got it broke in i checked my plugs to make sure it was not lean i have not really ran it wot to check my main jet yet thanks for the heads up on the jetting its my first banshee Quote Link to comment Share on other sites More sharing options...
donkeypuncher Posted February 11, 2009 Report Share Posted February 11, 2009 i run 80:1 amsoil saber. Quote Link to comment Share on other sites More sharing options...
official_style Posted February 11, 2009 Report Share Posted February 11, 2009 im planning on running yamalube R 28:1 this year. Quote Link to comment Share on other sites More sharing options...
250Rho Posted February 11, 2009 Report Share Posted February 11, 2009 anybody running yamalube any thicker than 32 is gonna foul plugs like a bitch. they may have said 24 when banch first came and oils were shitty out but a synthetic shouldnt be run nearly that thick. i know some of you run thicker than 32 but i dont hink your gaining anything but a bunch of burnt plugs. can you still buy a conventional 2 smoke oil?? keep an eye on your plugs, those jets sound small btw ther is a lot of threads on oil and i think someone put up a jetting chart that you can look at,not trying to be a dick jus lettin ya know. Quote Link to comment Share on other sites More sharing options...
jamebo Posted February 15, 2009 Report Share Posted February 15, 2009 anybody running yamalube any thicker than 32 is gonna foul plugs like a bitch.they may have said 24 when banch first came and oils were shitty out but a synthetic shouldnt be run nearly that thick. Been mixing that oil at 24:1 for a little over three years now and haven't fouled a plug yet. Mine actually doesn't smoke very much after it's warmed up, either. I have changed plugs a couple of times, like when I installed a coolhead and what-not, but never because they fouled on me and caused a running issue. Not saying I never will though, knock on wood..... Quote Link to comment Share on other sites More sharing options...
official_style Posted February 15, 2009 Report Share Posted February 15, 2009 Well you all convinced me, 32:1 it is. Quote Link to comment Share on other sites More sharing options...
2slow350 Posted February 15, 2009 Report Share Posted February 15, 2009 Well you all convinced me, 32:1 it is. Yep that's what I run.. 32:1 on gas 927 castor, 20:1 on alky klotz... Quote Link to comment Share on other sites More sharing options...
TJScott Posted February 15, 2009 Report Share Posted February 15, 2009 alot of people run up to 50:1 with synthetic no probs. i definitely wouldnt recommend it with a banshee though. if your on the pipe ALOT then i would go with 32:1 to keep everything good and lubed. if your not, i would go with 40:1 to keep everything inside clean and it will give you a small boost. cant go wrong with yamalube :cool: Quote Link to comment Share on other sites More sharing options...
