just a reminder to everyone
i read a lot of posts where guys are having issues getting their clutches adjusted properly.. or its fine for a long time and then all of a sudden something is wrong..
clutch cables need to be replaced every so often. ive been running the same one for a couple years now, and its stretched a lot..
i just put a new one in and in order to get my clutch adjusted back properly i had to adjust the pancake bearing. this is due to the cable stretching. id say it stretched 1/8" or so.. that may not seem like much, but in the world of adjusting clutches it can be a real pain in the ass.
so anyway, just a reminder to everyone.
Dude, could you use a capital letter once in awhile? Like at the beginning of your sentences? Really makes your posts hard to read. LOL!
SP
Loco,
Help me understand how the cable plays a role in the adjustment of the push rod? I align the lever on the case with the arrow without the cable installed. If the cable is too short or too long, I adjust it with the adjustment screw on the handle bars, or get a longer adjusment screw (i.e. stock) for an aftermarket lever where the screw is too short to have enough adjustment.
Maybe I'm missing something? I can definitely see how a stretched or too short (new) cable could be compensated for by adjusting the pancake bearing/push rod, but it would then misalign the lever with the arrow (if it had been previously aligned). :geek:
What problem were you having that required you to adjust the pancake bearing? Slippage or creeping with clutch engaged and whilst in gear?
once i installed the new cable, i had to adjust the pancake bearing so that i would still have my adjustment on the perch. otherwise, i had none.
Loco,
my clutch arrow does not exactly line up with my clutch arm. ive heard of other people having this same issue. i dont go by that arrow at all.
this post really didnt have as much to do with the fact that i had to adjust the pancake bearing. the fact that i had to adjust my bearing led me to figuring out my cable had stretched. some people may never have these issues, and some will.
like i said above, i dont go by that arrow. if i had, and left the pancake bearing, i wouldve had no shortening adjustment on my perch. so i say fuck the arrow, and adjust the pancake to where ive got adjustment both ways on the perch..
