  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
I like it but how does it seal up around the stator / flywheel to keep it from rusting?
If just using the bearing plate and not our stator cover portion then you have to modify your plastic cover. We offer a aluminum plate to use under your stock cover with two gaskets. You still would have to eboxy your cover but much easier to do using the plate we provide. If you buy our two or three piece set then it seals completely with the cover and provided gasket.
