SLORYDER Posted February 4, 2009 Report Share Posted February 4, 2009 As far as inframe vs. out of frame drag pipes, I understand that there is a 2 or so hp difference, but is it really noticeable at the track? Also, do they make heavy duty crank, tranny, and rod bearings; and if so, where is a good place to order? I have done several top end rebuilds, two and four stroke, but have never actually split the cases and got into the tranny. How difficult will it be for me to put a duneable override in? Who is a good builder that I can deal with as far as pistons, gaskets, ect. Someone with good customer suport. Thanxx in advance Quote Link to comment Share on other sites More sharing options...
Hilarious Posted February 5, 2009 Report Share Posted February 5, 2009 As far as inframe vs. out of frame drag pipes, I understand that there is a 2 or so hp difference, but is it really noticeable at the track? Also, do they make heavy duty crank, tranny, and rod bearings; and if so, where is a good place to order? I have done several top end rebuilds, two and four stroke, but have never actually split the cases and got into the tranny. How difficult will it be for me to put a duneable override in? Who is a good builder that I can deal with as far as pistons, gaskets, ect. Someone with good customer suport. Thanxx in advance in frame vs. out of frame exhaust, you may not feel the difference in your pants but you can see it on a time slip. lol splitting the cases and installing the override is peaches. you can visit one of the sponsors here, fast racing. he can head you in the right direction to get your parts and he's got pretty good customer service. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted February 5, 2009 Author Report Share Posted February 5, 2009 in frame vs. out of frame exhaust, you may not feel the difference in your pants but you can see it on a time slip. lolsplitting the cases and installing the override is peaches. you can visit one of the sponsors here, fast racing. he can head you in the right direction to get your parts and he's got pretty good customer service. So will I need to remove all the gears or just some? Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 5, 2009 Report Share Posted February 5, 2009 As far as inframe vs. out of frame drag pipes, I understand that there is a 2 or so hp difference, but is it really noticeable at the track? Also, do they make heavy duty crank, tranny, and rod bearings; and if so, where is a good place to order? I have done several top end rebuilds, two and four stroke, but have never actually split the cases and got into the tranny. How difficult will it be for me to put a duneable override in? Who is a good builder that I can deal with as far as pistons, gaskets, ect. Someone with good customer suport. Thanxx in advance they have billet cranks,billet trannys and tz bearings..what area are you in?? Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 5, 2009 Report Share Posted February 5, 2009 So will I need to remove all the gears or just some? your going to have to remove you stock tranny and drum and send it out to someone who deals with trannys.i use WCR.all his trannys come with warranty.. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted February 5, 2009 Author Report Share Posted February 5, 2009 they have billet cranks,billet trannys and tz bearings..what area are you in?? No, I meant heavy duty bearings for the crank, rods, and tranny. That is, if the stock bearings will be insufficient. I expect 110-120 hp from this setup....I should be safe w/ stock gears and 10mil crank, shouldn't I? Quote Link to comment Share on other sites More sharing options...
okbeast Posted February 5, 2009 Report Share Posted February 5, 2009 No, I meant heavy duty bearings for the crank, rods, and tranny. That is, if the stock bearings will be insufficient. I expect 110-120 hp from this setup....I should be safe w/ stock gears and 10mil crank, shouldn't I? What's the bike going to be used for? As for bearings for the crank a TZ bearing would probably be worth the money for the PTO side, unless you're gonna go to straight cut gears. Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 5, 2009 Report Share Posted February 5, 2009 No, I meant heavy duty bearings for the crank, rods, and tranny. That is, if the stock bearings will be insufficient. I expect 110-120 hp from this setup....I should be safe w/ stock gears and 10mil crank, shouldn't I? 10mill what??I have a freind that has a 10mill dm that was braking trannys left and right.went and bought a billet tranny and havent had that problem any more. Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 5, 2009 Report Share Posted February 5, 2009 sorry didnt see the 521..lol Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted February 5, 2009 Author Report Share Posted February 5, 2009 (edited) What's the bike going to be used for? As for bearings for the crank a TZ bearing would probably be worth the money for the PTO side, unless you're gonna go to straight cut gears. 25% dune riding/ 75% drag racing Gonna keep the PV's No alcohol Edited February 5, 2009 by SLORYDER Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 5, 2009 Report Share Posted February 5, 2009 I know it's a little off topic, but you can't get a 521 Cheetah. I'm building a 10mil Cheetah myself, and I thought you could get them with a 72mm bore, but you can't You have to get a 73mm bore, which makes it 535. That's what I had to do. Quote Link to comment Share on other sites More sharing options...
Blewbyu Posted February 5, 2009 Report Share Posted February 5, 2009 I know it's a little off topic, but you can't get a 521 Cheetah. I'm building a 10mil Cheetah myself, and I thought you could get them with a 72mm bore, but you can't You have to get a 73mm bore, which makes it 535. That's what I had to do. That's not true, there are 10 cheetahs out there with 72, 72.5, 73 bores. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 5, 2009 Report Share Posted February 5, 2009 That's not true, there are 10 cheetahs out there with 72, 72.5, 73 bores. I tried to order one, and Andy at M&M told me that the closest thing that you can get to a 72mm in a PV motor, is 73mm bore. Straight from my email: > ----- Original Message ----- > From: "Andy Meek" <atvsales@treeshear.com> > To: "'***** *****'" > Sent: Tuesday, January 06, 2009 4:56 PM > Subject: RE: Enquiry from M&M ATV - Yamaha Banshee and ATV Performance > Parts > > >> Chris, >> The 10mm cheetah they only got in a 73 bore. That is a small flange too. >> Let me know when your ready. >> >> Thanks >> Andy Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted February 5, 2009 Author Report Share Posted February 5, 2009 I tried to order one, and Andy at M&M told me that the closest thing that you can get to a 72mm in a PV motor, is 73mm bore. Straight from my email: > ----- Original Message ----- > From: "Andy Meek" <atvsales@treeshear.com> > To: "'***** *****'" > Sent: Tuesday, January 06, 2009 4:56 PM > Subject: RE: Enquiry from M&M ATV - Yamaha Banshee and ATV Performance > Parts > > >> Chris, >> The 10mm cheetah they only got in a 73 bore. That is a small flange too. >> Let me know when your ready. >> >> Thanks >> Andy Trinity originally built this motor 5 years ago. It has an original 72mm bore, as evidenced by the 72 marking on the powervalves. Anyone else have good feedback for F.A.S.T.? Quote Link to comment Share on other sites More sharing options...
okbeast Posted February 5, 2009 Report Share Posted February 5, 2009 That's gonna be one heck of a duner! I'd ask a builder or someone else on this one. I'd say maybe a billet 2nd would be a good idea, but I'd ask someone who builds the overrides (assuming you're getting one of course) how they would hold up. Quote Link to comment Share on other sites More sharing options...
