Stock chain adjustment
jamebo
I just adjusted my chain the other day by the owners manual. The book said to position the bike where the chain is tightest, then with no weight on it to adjust it to where it has 15-20mm/0.59-0.79in slack up and down on the top.
I adjusted it to about an inch or slightly less, but when I get on the bike the chain seems pretty tight with the shock compressed. Is this correct? I followed the directions, but it just seems like it may be a little too tight.
I want to make sure it's right so I don't cause any possible damage.
Anybody?
When sitting on the bike should there be any play, or is it alright for it to be tight with little to no movement up and down?
With weight on the bike the chain will get tighter. I have mine where it's got about 1/4 inch of play both ways with me on it. Never had a problem. If it's too tight when you sit on it then you will have issues when you jump or hit bumps.
Thanks for the reply, Jason. I'll check it and adjust it to those measurements. I appreciate it.
THE STOCK CHAIN ADJUSTMENT ON A BANSHEE SUCKS BALLS.
BUY A ROUNDHOUSE STYLE SWINGER, THATS WHAT ILL BE DOING WHEN I GET BACK FROM GLAMIS.
Makes it alot easier to adjust.
just my .02cents
yea i know. i will be doing different swingers on both of my bikes, but the stock chain adjusters are still fine for now, so why go blow a bunch of cash when i dont need to yet.
