lokisbuddy Posted February 4, 2009 Report Posted February 4, 2009 http://www.rockymountainatv.com/productDet...dFamilyId=19372 I wouldnt buy one right away but eventually maybe, unless i get the dyna fs Quote
jbooker82 Posted February 4, 2009 Report Posted February 4, 2009 It probably works off the same principle as Nology Hot wires. I run a nology coil and a set of hotwires. There are several people on here that run the nology setup. josh Quote
2001Stroker Posted February 4, 2009 Report Posted February 4, 2009 I'm just curious. Why would you need that on a stock bike? Then you would have to buy 2 of them, at $189.99 a piece. I think you can spend $400 on something better than some "spark enhancers". You could get port work, bigger carbs and intakes, a-arms, or something else for that kind of money. Quote
lokisbuddy Posted February 4, 2009 Author Report Posted February 4, 2009 I'm just curious. Why would you need that on a stock bike? Then you would have to buy 2 of them, at $189.99 a piece. I think you can spend $400 on something better than some "spark enhancers". You could get port work, bigger carbs and intakes, a-arms, or something else for that kind of money. Hence the reason I said I would not buy them right away but eventually maybe. Quote
