ericsullivan Posted January 30, 2009 Report Share Posted January 30, 2009 pry a stupid question bot when i put oil in my banshee it leaks out under the water pump ?????? i put the outer cover on and it leaks out the bottom should there be a gasket or should i use rtv or why is it leakn???? thanks guys Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 30, 2009 Report Share Posted January 30, 2009 there is a vent hose that goes back there. It is probaby poped off or not there. Quote Link to comment Share on other sites More sharing options...
ericsullivan Posted January 30, 2009 Author Report Share Posted January 30, 2009 there is a vent hose that goes back there. It is probaby poped off or not there. thank you do you know where i should run the vent hose out im not see n ne thing i had bought the plug that goes there but it is not what i thought so it does have the plug but no vent hose??? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted January 30, 2009 Report Share Posted January 30, 2009 thank you do you know where i should run the vent hose out im not see n ne thing i had bought the plug that goes there but it is not what i thought so it does have the plug but no vent hose??? some put a rubber plug over that vent. there is a small hole in the clutch cover over the water pump to route the vent line up to the frame underneath the gas tank. Quote Link to comment Share on other sites More sharing options...
