Gasket or sealeant between intake and reeds?
VWMIKE
Just putting back together the shee after taking it apart and cleaning things up, and to see what the previous owner had done to it. I know there is a gasket between the reed cage and cyl. But what about the intake manifold to reed cage? Mine had no gaskets just sealant, is this normal? The online microfiche only shows 1 gasket per side as well? Just wondering what everyone uses. thanks
Mike
Yeah, should be a total of 4 gaskets...2 per side, one for each side of the reed, I also put a thin bead of 1211 sealer on each of the gasket surfaces, front and back, to make sure I have a perfect seal every time.
X2 on that shit, thats what we did 4 gaskets and 1211 like stated xtra insurance.
use 4 gaskets and sealer. works great every time.
Word.
I use a thin coat of RTV, ANY RTV, on either side of both gaskets, per side.
I know the gasket alone should be enough...but with how bad air leaks are for these, what's 10 extra minutes to put a skim coat on the gaskets?
The reed cages and intakes need to be sealed....
