millertime Posted January 28, 2009 Report Share Posted January 28, 2009 (edited) i am looking for some 4 mill long rod cool head domes... 18cc - 17 cc.... either will work for us we are at 5,000 feet .... new or used ... just thought i would see here before i order some you can e-mail me to... this is for my boys banshee.. so i am not on this site alot.. i have a 501 yfz millertime4060@cableone.net Edited January 28, 2009 by millertime Quote Link to comment Share on other sites More sharing options...
98_shee Posted January 28, 2009 Report Share Posted January 28, 2009 I have a set of 18's, if i can find some 20 or 21 that are not cut I will sell them. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted January 28, 2009 Report Share Posted January 28, 2009 What is a long rod dome? Quote Link to comment Share on other sites More sharing options...
banshee_terror_ Posted January 28, 2009 Report Share Posted January 28, 2009 i have 17's but i dont know if they were cut Quote Link to comment Share on other sites More sharing options...
98_shee Posted January 28, 2009 Report Share Posted January 28, 2009 What is a long rod dome? they are cut so the piston can slide in them. so you don't have to run a spacer plate with the long rod crank. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted January 28, 2009 Report Share Posted January 28, 2009 they are cut so the piston can slide in them. so you don't have to run a spacer plate with the long rod crank. I have never heard of someone cutting a dome to compensate for a long rod. You cut a dome to compensate for stroke and run a different piston w/different pin placement to compendate for the extra rod length. And a cut dome is real obvious...there is quite a step cut into it. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 28, 2009 Report Share Posted January 28, 2009 They are mistaken.... Piston type makes up the 5mm offset, not the domes. He needs 4 mil stroker domes...the dome is cut 2mm deeper to compensate for the 2mil extra stroke at TDC. Unless he wants to run a 10 mil crank with sleeves...then he could cut the domes 5mm to make up for the sleeves sticking out of the top...but that's another story. Long rod and stroker crank are two separate things, each requiring something different to make them work. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted January 29, 2009 Report Share Posted January 29, 2009 I carry the 4mm cut domes if i can help give me a hollar. Quote Link to comment Share on other sites More sharing options...
SonOfSand Posted January 29, 2009 Report Share Posted January 29, 2009 i am looking for some 4 mill long rod cool head domes... 18cc - 17 cc.... either will work for us we are at 5,000 feet .... new or used ... just thought i would see here before i order some you can e-mail me to... this is for my boys banshee.. so i am not on this site alot.. i have a 501 yfz millertime4060@cableone.net Is this millertime from Rigby? I rode with you and your son this summer, you had some friends down from nothern Id as well. I was on my blue Raptor cause my YFZ had just cracked the cyclinder. What did you do to your boys bike, it was already pretty quick? Quote Link to comment Share on other sites More sharing options...
millertime Posted January 30, 2009 Author Report Share Posted January 30, 2009 Is this millertime from Rigby? I rode with you and your son this summer, you had some friends down from nothern Id as well. I was on my blue Raptor cause my YFZ had just cracked the cyclinder. What did you do to your boys bike, it was already pretty quick? ya .. this is corey.... i am putting a stroker crank in it... and a bunch of other things... it is what he wanted for christmas... only about 1,200.00 worth of parts... then all my time doing it.. ... i have my orange yfz 501 stripped down to the frame to.. it is getting a big make over to.. and it is not even a year old.. hope to see you out there this summer.... i can't wait to ride agin. i have bought some domes from Herr racing.... thanks everyone.... Quote Link to comment Share on other sites More sharing options...
SonOfSand Posted January 30, 2009 Report Share Posted January 30, 2009 ya .. this is corey.... i am putting a stroker crank in it... and a bunch of other things... it is what he wanted for christmas... only about 1,200.00 worth of parts... then all my time doing it.. ... i have my orange yfz 501 stripped down to the frame to.. it is getting a big make over to.. and it is not even a year old.. hope to see you out there this summer.... i can't wait to ride agin. i have bought some domes from Herr racing.... thanks everyone.... Corey, you have peaked my curiosity, I bought a banshee in December with the intent of building for spring. I would be very interested to hear what you are going to do to it. I am thinking 4 mil dune port by Herr or FAST. What could you be doing to your 450? It was already one of the fastest i have seen out there. We only have 2 more months, we should hook up on opening day. I cant wait!! Quote Link to comment Share on other sites More sharing options...
millertime Posted January 31, 2009 Author Report Share Posted January 31, 2009 your choice on your banshee should be good..... it all about how much money you want to spend... LOL on my 501... i got rid of alot off it.. no more nerfs or heal gaurds.. got rid of the e-start.. no fan.. gutted the wire harness.. custom sub frame.. new pipe.. 22-12-8 12 paddle super light gliders... + 6 swing arm... going thru the motor and see if i can find a few more ponies in it... new piston.. new valves.. re cut the seats.. maybe shave .020 off the head.. put hot start on... maybe ditch the front brakes.. no rear fenders... new paint... should be nice looking.... ya if i can get the day off i would like to be out there opening day... i am sure i will be out there to run on crapo before that to get it dialed in agin tho... i am sure we will get to ride together more this summer.. Quote Link to comment Share on other sites More sharing options...
SonOfSand Posted January 31, 2009 Report Share Posted January 31, 2009 your choice on your banshee should be good..... it all about how much money you want to spend... LOL on my 501... i got rid of alot off it.. no more nerfs or heal gaurds.. got rid of the e-start.. no fan.. gutted the wire harness.. custom sub frame.. new pipe.. 22-12-8 12 paddle super light gliders... + 6 swing arm... going thru the motor and see if i can find a few more ponies in it... new piston.. new valves.. re cut the seats.. maybe shave .020 off the head.. put hot start on... maybe ditch the front brakes.. no rear fenders... new paint... should be nice looking.... ya if i can get the day off i would like to be out there opening day... i am sure i will be out there to run on crapo before that to get it dialed in agin tho... i am sure we will get to ride together more this summer.. Wow, sounds like you are moving more towards racing up the hill. What color are you going? should be much lighter then before. I am excited to see your bike run, let me know when you are going to crapo's, would like to tag along if its ok. Quote Link to comment Share on other sites More sharing options...
millertime Posted February 1, 2009 Author Report Share Posted February 1, 2009 it will still be orange... but i am going to paint the frame white then shoot candy orange over the white.. then alot of clear... should look good... once the snow melts i will let you know when i am going out.. it be great to have you out there with us.. Quote Link to comment Share on other sites More sharing options...
