dragbanshee Posted January 25, 2009 Report Share Posted January 25, 2009 Something weird going on for sure, when you get a new nut to put on, does it spin on freely from the start or is it tight instantly? I have never had a problem with this either and I just snug them fairly tight. I dont see how this could be happening unless the shaft is screwed, but I trust when you say it isn't. If your lucky, you just got a couple bad ones, doughtful, Good luck with it! Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 25, 2009 Author Report Share Posted January 25, 2009 (edited) Something weird going on for sure, when you get a new nut to put on, does it spin on freely from the start or is it tight instantly? I have never had a problem with this either and I just snug them fairly tight. I dont see how this could be happening unless the shaft is screwed, but I trust when you say it isn't. If your lucky, you just got a couple bad ones, doughtful, Good luck with it! no they have threaded on by hand, easily , both times ive replaced them, no resistance, i thread it all the way down by hand, and hand snug it, then put the chain on, have somsone hold the brakes then tighten good with the wrench.. im fuckin cluless on whats goin on here, when it warms up a bit ill throw another one on, ill put it on with a 32mm socket tight as hell and hope for the best... Edited January 25, 2009 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
fox_forma Posted January 28, 2009 Report Share Posted January 28, 2009 2 of us had ours back off on us at the dunes at halloween, I had the washer bent over in two places as well and it still somehow got loose. Not sure if somehow it gets just a little loose and causes the washer to come out of its grooves and allow it to turn off or what but I impacted that bitch back on this time around. Quote Link to comment Share on other sites More sharing options...
CBAIER1206 Posted January 28, 2009 Report Share Posted January 28, 2009 Give her a quick zap with an impact...you'll never have a problem with it again! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 28, 2009 Report Share Posted January 28, 2009 2 of us had ours back off on us at the dunes at halloween, I had the washer bent over in two places as well and it still somehow got loose. Not sure if somehow it gets just a little loose and causes the washer to come out of its grooves and allow it to turn off or what but I impacted that bitch back on this time around. i think thats it.. ive noticed that some of my sprockets are just a little wider than others. not sure why or if this is a common occurrence. but it looks to be like the clip barely catches the splines. i mostly run sprocket specialist ones because i run 15, 16 and 17 tooth.. sometimes my clip doesnt wanna sit on the splines very well. i can see how if you dont use an impact that the clip never really sits on the splines. MJ, im betting this is your problem. Quote Link to comment Share on other sites More sharing options...
spike Posted January 28, 2009 Report Share Posted January 28, 2009 I had problems with this in the past and one days i figured out that i could bend the retainer on 3 edges instead of the 2 normaly. never had any problem ever since. also make sure you bend them over real tight and dont reuse them more than once or twice... there cheap Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 28, 2009 Author Report Share Posted January 28, 2009 thanks for all the replies, i will try everyone tips as soon as it warms up a bit and hope for the best, thanks guys Quote Link to comment Share on other sites More sharing options...
Chariot Performance Posted January 30, 2009 Report Share Posted January 30, 2009 so if this is correct what ur saying about snugging it a bit, why the hell would mine be coming off? when i first put it on, its tight as can be, there is no slop in the threads, 8 months later the threads on the nut are all chewed up, again, but the threads on the shaft are fine, the nut must be softer metal, no ? Does the sprocket move on the shaft forward and backward. Slop on the teeth of the shaft or id. of the sprocket? Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 30, 2009 Author Report Share Posted January 30, 2009 (edited) Does the sprocket move on the shaft forward and backward. Slop on the teeth of the shaft or id. of the sprocket? no theres really no play in the sprocket itself, the play is in the nut only, it has play forwards and backwards on the threads and it looks like a little in and out play on the shaft too, just like last time, im gona toss on a new one in a few days, and i just ordered a backup one and lockwasher from yamaha today, little fuckers are expensive, like $10 for nut and washer Edited January 30, 2009 by Michael Jackson Quote Link to comment Share on other sites More sharing options...
spurdy Posted January 30, 2009 Report Share Posted January 30, 2009 (edited) , but your right, its still nigger rigged, i will buy a socket You can't say nigger rigged.....it is now called a"presidential solution". SP Edited January 30, 2009 by spurdy Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 30, 2009 Author Report Share Posted January 30, 2009 You can't say nigger rigged.....it is now called a"presidential solution". SP amen, and i apologize, change is here! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 30, 2009 Report Share Posted January 30, 2009 amen, and i apologize, change is here! nigga plz Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 30, 2009 Author Report Share Posted January 30, 2009 see you in the cotton field tomorrow morning loco, 6am sharp Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 30, 2009 Report Share Posted January 30, 2009 see you in the cotton field tomorrow morning loco, 6am sharp no racial comments on HQ. you have been warned.. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 30, 2009 Author Report Share Posted January 30, 2009 hard to take that seriously coming from you.. and i never said anything racist ? its just one of the many obama jokes .. Quote Link to comment Share on other sites More sharing options...
