Draining Coolant ?
Im Wanting to drain the coolant. I was Told there is a drain plug near the water pump. Cant find it
the only drain plug that i know of is on the outside of the cylinders but that just drains the jugs. i could be wrong though. i just pop the radiator hoses off and let her drain. good luck.
Pull the rad. cap, drop the lower rad hose from RS cover and tip bike side to side, also drain bolt on side of each cylinder. Aftermarket makes a drain bolt/cover for inside the wp cover but stock doesnt have one.
