fastrthnu Posted January 23, 2009 Report Share Posted January 23, 2009 alot of times I ride for fun, but I also race when my bike doesnt have sand in its vagina. now anyone who has raced an mx track knows what it does to your forearms and being a 2 stroke usually requireds more frequent shifting. Ok after 4 minutes my fucking hands dont really feel like holding on anymore let alone pulling that lever every 5 gd seconds. would it be worth buying an override to eliminate that problem. does anyone use one? I dont know very much about these things. What type should I look for. Ect.. Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted January 23, 2009 Report Share Posted January 23, 2009 A N down 1-5 duneable override works like a champ in the dunes. WCR cuts a variety of configurations. The website is w-c-r.com if you want to check them out. I don't have a clue what would work for you, but the N1-5 works great in the dunes hillshooting and general riding. Not sure if the neutral down is the best for an MX track. You definitely do not want a standard override, but you would have figured that out quickly anyway. :thumbsup: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 23, 2009 Report Share Posted January 23, 2009 Let me know if you need an override.... You will still have to pull the clutch to downshift, so I honestly don't know how much of a help it's going to be for you. They are cut to engage with pressure on them (engine power) and upshifted. They are not cut to shift backwards without the clutch... I would not recommend that, even with a dunable override... So if it's still your cup of tea, let me know. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted January 23, 2009 Author Report Share Posted January 23, 2009 Let me know if you need an override.... You will still have to pull the clutch to downshift, so I honestly don't know how much of a help it's going to be for you. They are cut to engage with pressure on them (engine power) and upshifted. They are not cut to shift backwards without the clutch... I would not recommend that, even with a dunable override... So if it's still your cup of tea, let me know. nah, it doesnt even sound worth it if it doesnt shift both ways. That would have been the shit. Ill pm you if I decide I wanna get one. Thanks. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 23, 2009 Report Share Posted January 23, 2009 I thought I read somewhere that Loco said he upshifts and downshifts his without the clutch.... I can tell you I've NEVER downshifted mine (while running) without the clutch pulled in. Totally your call...but I wouldn't warranty or expect one to last downshifting under full load... Quote Link to comment Share on other sites More sharing options...
okbeast Posted January 23, 2009 Report Share Posted January 23, 2009 I thought I read somewhere that Loco said he upshifts and downshifts his without the clutch....I can tell you I've NEVER downshifted mine (while running) without the clutch pulled in. Totally your call...but I wouldn't warranty or expect one to last downshifting under full load... Wouldn't you still be backloading the transmission even if you pulled the clutch in before downshifting? Seems like it'd be alot of wear and tear. On another note I think a few Flat track/TT guys have used duneable overrides before with success, granted they probably aren't shifting quite as much but still. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 23, 2009 Report Share Posted January 23, 2009 No... Backloading is letting off the gas and NOT pulling the clutch in. Quote Link to comment Share on other sites More sharing options...
okbeast Posted January 23, 2009 Report Share Posted January 23, 2009 No...Backloading is letting off the gas and NOT pulling the clutch in. Let me re-phrase. You pull in the clutch at high rpm's and downshift and when you let the clutch out and it revs the motor up would this not be bad? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 23, 2009 Report Share Posted January 23, 2009 If you repeatedly let the clutch out and are NOT on the gas at higher RPMs, you will wear the shift forks out sooner, but won't bend or break anything. As noted, TT guys have run a few seasons on the same shift forks, and they're on/off the gas plenty...at max/higher RPMs. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted January 23, 2009 Report Share Posted January 23, 2009 Let me re-phrase. You pull in the clutch at high rpm's and downshift and when you let the clutch out and it revs the motor up would this not be bad? Yes.. that would be backloading.. Any time you use engine braking.. is bad. Quote Link to comment Share on other sites More sharing options...
