studroes Posted January 21, 2009 Report Share Posted January 21, 2009 ok this may be a dumb question but ill ask anyways..do all stroker cranks come with the 115 rods? and also..do you always have to use the 795 pistons with any stroker or are instances when you dont? Quote Link to comment Share on other sites More sharing options...
98_shee Posted January 21, 2009 Report Share Posted January 21, 2009 You can get a stroker with the 110 rods. The 795 series pistons are for the 115 rods. Quote Link to comment Share on other sites More sharing options...
gregrob Posted January 22, 2009 Report Share Posted January 22, 2009 No, they dont all come w/ 115 rods. You can get a 4mil with either 110 or 115. and other, larger strokes have different rod length options. Quote Link to comment Share on other sites More sharing options...
studroes Posted January 22, 2009 Author Report Share Posted January 22, 2009 ok thanks guys..does anyone know what rods come with a vitos 4mil? i bought a new 4mil off ebay and its a vitos but there wasnt any info on it an im just curious what pistons ill need Quote Link to comment Share on other sites More sharing options...
98_shee Posted January 22, 2009 Report Share Posted January 22, 2009 ok thanks guys..does anyone know what rods come with a vitos 4mil? i bought a new 4mil off ebay and its a vitos but there wasnt any info on it an im just curious what pistons ill need You will have to ask the person you got it from. If its a long rod you will need the 795's and you will need to run a spacer plate (not recomended) or have your domes cut or order a set of cut domes. I may have a set of cut domes for sale if i find another set. Quote Link to comment Share on other sites More sharing options...
studroes Posted January 22, 2009 Author Report Share Posted January 22, 2009 i have tried to contact the person but they dont respond to my emails so im out of luck there. is there any way to tell or anything i could measure on the crank or rods? Quote Link to comment Share on other sites More sharing options...
mun2frio Posted January 22, 2009 Report Share Posted January 22, 2009 i have tried to contact the person but they dont respond to my emails so im out of luck there. is there any way to tell or anything i could measure on the crank or rods? Go to Vito's website get the phone number and call them they will help you. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted January 22, 2009 Report Share Posted January 22, 2009 You can measure from the center to center of the connecting rod eyes. Quote Link to comment Share on other sites More sharing options...
studroes Posted January 22, 2009 Author Report Share Posted January 22, 2009 how would you be able to be sure it is right in the center? does anyone know the number it will be from the very top to the bottom of the rod or can that vary from differents cranks too? Quote Link to comment Share on other sites More sharing options...
studroes Posted January 22, 2009 Author Report Share Posted January 22, 2009 ok i just looked on the vitos site and they only sell one type of 4mil crank and that uses the 110 rods so that means i can use and regular banshee piston right? and will this type of crank need different cut domes than what one with 115 rods will need? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted January 23, 2009 Report Share Posted January 23, 2009 ok i just looked on the vitos site and they only sell one type of 4mil crank and that uses the 110 rods so that means i can use and regular banshee piston right? and will this type of crank need different cut domes than what one with 115 rods will need? domes`are the same whether its a 110 rod or a 115. the 795 series compensates for the 115mm rod. Quote Link to comment Share on other sites More sharing options...
studroes Posted January 23, 2009 Author Report Share Posted January 23, 2009 does the porting for the 4mil changes between the 110 and 115 rods or do the pistons compensate for that aswell? Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted January 24, 2009 Report Share Posted January 24, 2009 does the porting for the 4mil changes between the 110 and 115 rods or do the pistons compensate for that aswell? pistons compensate for that too. think about it this way. the 115mm rod is 5mm longer right? well the 795 series pistons have the wrist pin location moved up 5mm. so the piston height is the same as with 110mm rods and stock pistons. hope this helps. Quote Link to comment Share on other sites More sharing options...
studroes Posted January 24, 2009 Author Report Share Posted January 24, 2009 yupp that does, i just wanna make sure i have everything straightened out before i buy the rest of my parts lol thanks guys Quote Link to comment Share on other sites More sharing options...
