banshee31 Posted January 20, 2009 Report Share Posted January 20, 2009 Wondering if anyone has an opinion concerning case savers. Do they work and what style to get? Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted January 20, 2009 Report Share Posted January 20, 2009 Yes, and get the plastic one, not the billet. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted January 20, 2009 Report Share Posted January 20, 2009 Both work fine. :thumbsup: Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted January 20, 2009 Report Share Posted January 20, 2009 I'd be afraid of the billet one transferring the force from the chain. At least the plastic one has a breaking point. I think most would agree. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted January 20, 2009 Report Share Posted January 20, 2009 Ive tried both, and both do what there supposed to. As long as you run a good quality chain and the tention is checked frequently and you maintain your chain properly and not run an e-bay special chain there should be no chain snapping or popping off to worry about. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 20, 2009 Report Share Posted January 20, 2009 go with plastic. billet ones can bend and still fuck up your cases. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted January 20, 2009 Report Share Posted January 20, 2009 That is true though. Always run a quality chain...especially on these bikes. High RPMs and high MPHs...don't skimp out and get a chinese chain on Ebay. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 20, 2009 Report Share Posted January 20, 2009 TM Designworks is the only one to get. Quote Link to comment Share on other sites More sharing options...
BlasterKX Posted January 20, 2009 Report Share Posted January 20, 2009 i got a ebay chain with new sprockets and its a oring Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 20, 2009 Report Share Posted January 20, 2009 Ive tried both, and both do what there supposed to.As long as you run a good quality chain and the tention is checked frequently and you maintain your chain properly and not run an e-bay special chain there should be no chain snapping or popping off to worry about. bull shit. quality of chain has nothing to do with this. ive had high dollar d.i.d. chains come apart.. ive also broken front sprockets. anything can happen. you could get a fucking twig stuck in there that could cause a problem. a billet case saver can and will break your case just as easily as the chain will. plastic is the only way to go. Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted January 20, 2009 Report Share Posted January 20, 2009 bull shit. quality of chain has nothing to do with this. ive had high dollar d.i.d. chains come apart.. ive also broken front sprockets. anything can happen. you could get a fucking twig stuck in there that could cause a problem. a billet case saver can and will break your case just as easily as the chain will. plastic is the only way to go. Never happened to me before. On a few different quads and dirt bikes over the years. Guess you luck sucks. Quality "helps" man and you know it. Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted January 20, 2009 Report Share Posted January 20, 2009 (edited) just get a plastic one. Doesnt have to be the TM one. I have one of ebay that a machine shop made and it actually braces more of the case than the TM one. I have also run the ebay china chain for over 3 years with no problem. And their sprockets. Just make sure you keep up on your maitnence. Make sure it is adjusted correctly, lubed well, sprocket nuts are tight, clean the junk out of there after every ride. A clean, well maintained mahine will ALWAYS run and last longer. Edited January 20, 2009 by boneyardbanshee. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 20, 2009 Report Share Posted January 20, 2009 Never happened to me before. On a few different quads and dirt bikes over the years. Guess you luck sucks.Quality "helps" man and you know it. in most cases yes, i agree that quality does count. in this case it doesnt. even the best chains out there can break due to freak shit like a rock or something hitting them. the billet ones most def will break the cases the same as a chain, maybe worse. plastic is the best way to go in this situation. Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted January 20, 2009 Report Share Posted January 20, 2009 I bought the billet one and have regretted it ever since I seen the T.M. Design, didn't realize they had the plastic ones at the time. Its common sense though, being billet, metal of any type and bolting up the way they do is bound to break the case if the chain ever comes off. Atleast the T.M. has extra bracing and able to flex if forced, I'll be switching. Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted January 20, 2009 Report Share Posted January 20, 2009 TM Designworks is the only one to get. i second the tm design works Quote Link to comment Share on other sites More sharing options...
