Adjusting stock correctly..
hollisatp
Adjusting Stock What????? :blink: Suspension i take it since it's in the suspension section, you talking about lowering, adding pressure etc.?
Im pretty certain all stock banshees came with an adjustable rear shock where you can adjust the compression and spring tension. :blink:
Yes its a shock question.. I wanted to make sure my suspension was set for my weight and riding style. Anyone know how to dial it in correctly? I have never changed it but think there is a "little" room for improvement..
The reason for sarcasm here is because every rider is different as is their preferences. I know your intention is good but to ask what setup is "dialed in" is a pretty vague question. What isn't your bike doing right? Is it too mushy or too stiff? What up?
Yeah I do understand that.. I just thought there might be a set path to follow to adjust.
Sit on it, check the compression of the springs, etc...
it is a little soft when I come up to a hill or the bottom of a dune... compresses a little too much..
But the back seems ok through woops.. maybe just the front needs adjustment..
Thanks in advance..
Thanks in advance..
The stock fronts only have preload adjustments, so you could increase that a notch or two. The rear if your only having problems with it on compression and ok with the rebound. since compression is easy to change I would try adjusting that a few clicks unless you are bottoming super hard. then you will need to increase preload maybe even a spring change. At 160 pounds you really shouldn`t need a spring change Thats in the range of the factory springs, when was the last time your was rebuilt? it may need to be gone through.
are the stock shocks able to be rebuilt?? They have never had one.. 9 years now...??? if so, what all is involved, time, $$, etc..
thanks!
the rear you could have rebuilt with out any problems. It depends on what you want done and the condition of your shock. I don`t think the fronts can be and even if they could it would be a waste of time and money. Prices will vary from shop to shop and as mentioned before what needs to be done. could be as cheap as a 150.00 to over 500.00 with new valving and spring etc.for fronts as mentioned before buy some good used or a new set depending on your cash flow. check around your area to see if anyone local does quality rebuilds if not your gonna have to ship yours off or oder another set.
