no impact flywheel removal
read the how to....... i have timing plate and flywheel puller in hand.... problem is i have no air compressor for my air tools.... so that being said whats the sure fire way to remove the flywheel without stripping the puller's threads? my flywheel is rusty as well as the bolt and nut and i can see this happening..... im going to soak it in some good penetrant for a hour or so before i even attempt and take a wire brush to the threads and clean em best i can...... but ne other old school tricks to break the nut free???? thats what i need!! thanks
go buy a cheap elect impact... if you cant do that you can try a tapping the rachet to get it to break lose but will be hard cus the bike and/or motor is gonna try moving... hammer/mallot tapping a rachet is poor mans impact..either way you still need a puller like nyuk says get 2 of them...
to bust the nut, :biggrin: put a breaker bar un there, and smack the handle with a hammer.... :woot:
hopefully your not talking about putting something in the small holes to hold the flywheel still. You will more then likley ruin your stator this way. If you have the means to drill, you can get a small peice of flat bar stock and use some long bolts that fit the holes in the side of the flywheel to make your self a tool to hold the flywheel in place. The inner hub tool made by motion pro has prongs on them but they suck, they do not hold very well.
no, i was talkin about puttin a breaker on the nut. i would just put it in 6th, if u can't build a tool
i personally wouldnt be tapping on anything with a hammer. go buy an electric impact if you have to.
no need to bang anythng if its braked in place,. and btw I dont suggest using an imapct gun on a flywheel puller or any puller for that matter. use 2 wrenches or a ratchet and wrench.
why wouldnt you use an impact? just curious as thats all ive ever used.. never broken a flywheel puller either.
i wouldnt tap the machine with a hammer.. but tapping a cheater bar or rachet is an old school impact.. just tapping to jar it so it will loosen just like an impact... myself use an impact and works nice.
i agree.. i see no difference really. plus you dont need 18 hands to hold the hammer, cheater bar and the motor.
Most people say not to use an impact on a puller because it will mess the treads up from time to time. I know i am sure lots of people do it myself included but thats why they say not to because it will ruin the threads once in a great while. As far as the hammer on a breaker bar thing goes it is really easy and as the other guy said it is a poor mans impact lol if you need more than 2 hands to do it you are just not old school enough i guess lol
