building 4mill Cub question?
b-nasty
Im building a 4 mill cub motor. Using a 4mill hotrods crank and cub cylinder with coolhead. With this setup do i need to run a spacer plate under the cubs or just have my domes cut for the 4mill. What works best. thanks
Did you buy a cub built for stock crank or for 4 mill crank?If its a 4 mill cub cylinder you wont need a spacer...If you find out that you do need a spacer just hit up HJR herrjugsracing,he has a guy that does a special cut for domes...
Yup, no 4 mil domes needed, they just need to be for the 68 mm bore. The 68 mm pistons are blaster pistons and have a different dome shape than the banshee pistons. Just order a set of domes for a 68 mm cub from one of the sponsored vendors on here and you will be fine. Because you have the 58x68 cylinder, you will not need a spacer and the pistons will not protrude from the top of the cylinder either. Check you squish clearance, and you want a MINIMUM of .040" My bike has .053 right now and seems to be fine although some have told me thats on the loose side of things.
My advice is get a set of domes for gas, and get a different set for alky once you switch over.
They are two different fuels with different explosion characteristics.
Nothing wrong with .053 squish.
Mine was at .055.
I could tighten mine up...but then I couldn't run as much timing as I want, and I can't hot lap it.
I will take the 5% performance decrease (if that) in order to be able to ride my bike...ALOT.
