werner Posted January 16, 2009 Report Share Posted January 16, 2009 Can I run 33m intakes with 28s? I have a set of Boss Billet intakes that I want to use. Will they clamp down enough? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 16, 2009 Report Share Posted January 16, 2009 You should be able to buy smaller intake boots with the same bolt pattern. Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted January 16, 2009 Report Share Posted January 16, 2009 i would find smaller intakes boots cus that gonna be alot and big chance of a leak not worth it... Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 20, 2009 Report Share Posted January 20, 2009 Here is a chart. See what intake boots your intake has on it now. I belive they are VM/34200-1 for the 33-35mm carbs. They have the mounting bolts 60mm center to center. So you would need the I-VM28-200-1 wich have the same 60mm bolt patter ony the smaller 26-28mm carb flange. http://www.sudco.com/flange.html josh Quote Link to comment Share on other sites More sharing options...
