blaster2006 Posted January 15, 2009 Report Share Posted January 15, 2009 heya, well, i got 2 oils here, and 2 questions, i need to know if these ones work for a banshee, i bought it used from a guy who was premixing 20:1, i wanna move up to 30:1 or 32:1, so first question: can i use this oil at 30:1 or 32:1? cause i know there is many kinds, like" T and 2T etc etc, whats the diff between them? i bought only 1 bottle, and they are out of stock from the local shop i bought em from, so what to do now? here is the 2 stroke motor oil: now for this, tranny oil its SAE 10W-30, synthetic, is this for a banshee ( i used to have it for my blaster), if so, how much ml is recommeded to put in? Quote Link to comment Share on other sites More sharing options...
98_shee Posted January 15, 2009 Report Share Posted January 15, 2009 Read on the bottle and see what it says for premix, I use Caster 927 and never had any problems out of it. As far as the tranny oil you need to make sure its designed for wet cluthes. I run maxima in the tranny. Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted January 15, 2009 Author Report Share Posted January 15, 2009 Read on the bottle and see what it says for premix, I use Caster 927 and never had any problems out of it. As far as the tranny oil you need to make sure its designed for wet cluthes. I run maxima in the tranny. ddnt know banshees have wet multipplate clutch? the premix has no reccomendation, it says for oil injection or premix, i want to know if i use this, then buy some other yamalube etc like 2T, but still yamalube and 2 stroke motor oil, if it wont be a problem, i dont think i can find the same exact kind as that oil.. thats why :S Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted January 15, 2009 Report Share Posted January 15, 2009 Best tranny oil IMO is Belray Gearsaver 85w and that's all I've ever run. Gear box takes 1500ml from empty. That 2-stroke oil you've got there has a picture of an outboard motor on it so that means it's a marine oil and I'm not too sure what you can mix that down to. I would recommend Amsoil Intercepter mixed at 40:1, hasn't let me down. Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted January 15, 2009 Report Share Posted January 15, 2009 An 80 or 85 weight gear oil is a much better choice than 10W-30, and as far as the premix, I have never used Yamalube of any kind. For some reason I think TC-W3 has something to do with outboard boat engines. Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted January 15, 2009 Author Report Share Posted January 15, 2009 An 80 or 85 weight gear oil is a much better choice than 10W-30, and as far as the premix, I have never used Yamalube of any kind. For some reason I think TC-W3 has something to do with outboard boat engines. the recommended oil for my blaster was SAE10W-30, from the manual, so i thought this was the recommened too for the banshee hehe... since its 2 stroke. so, what is the exact recommended oil use for the banshee? and i fill it up to 1500 ml? or did someone who said 1500 here mean halfway up to it? Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted January 15, 2009 Report Share Posted January 15, 2009 the recommended oil for my blaster was SAE10W-30, from the manual, so i thought this was the recommened too for the banshee hehe... since its 2 stroke. so, what is the exact recommended oil use for the banshee? and i fill it up to 1500 ml? or did someone who said 1500 here mean halfway up to it? The banshee manual says 10W-30 as well, but an 80 or 85 weight gear oil is just a better choice. 10W-30 will work if you choose to use it (as long as it is wet clutch approved). You also need to watch out for the motor oils with anti-friction additives, for the clutch will slip when those kinds are used. I am sure if you find an oil that is wet clutch approved, you will not have any issues with anti-friction additives. Just read the bottle carefully... The oil capacity is 1500 milliliters. You will need approximately 1.5 quarts of oil. Quote Link to comment Share on other sites More sharing options...
SpecialEd 05 Posted January 15, 2009 Report Share Posted January 15, 2009 If you drain the transmission completely then use 1500ml of 85w gear oil to refill it. If you're topping it up then just add the oil until it's at the top line of the dipstick. Being that you don't know what's in the transmission at the moment, I recommend changing the gear oil completely. Quote Link to comment Share on other sites More sharing options...
elwilliams13 Posted January 15, 2009 Report Share Posted January 15, 2009 The yamalube you got there is used for outboards and your blaster if you had the injection system hooked up. The main diffrence is the parrafin content the 2s has to be thinner to run through the injector system. You can run it premixed but the yamalube 2r is designed as a premix and is a heavier oil try and get some of that if you can. There are a gazillion oils out there for premix applications do a search. Hoped this helps. Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted January 15, 2009 Author Report Share Posted January 15, 2009 The yamalube you got there is used for outboards and your blaster if you had the injection system hooked up. The main diffrence is the parrafin content the 2s has to be thinner to run through the injector system. You can run it premixed but the yamalube 2r is designed as a premix and is a heavier oil try and get some of that if you can. There are a gazillion oils out there for premix applications do a search. Hoped this helps. nah hehe, i used to use something called" caltex revtex" for my blaster, it said "recommended for oil injection or premix of 50:1" Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted January 15, 2009 Report Share Posted January 15, 2009 I think that premix pictured is for 2 stroke outboards. I wouldn't run it in a banshee. I actually would not use either one. I am a formulated 2 stroke oil fan. Whether it be cylinders or transmission. Quote Link to comment Share on other sites More sharing options...
rtcc Posted January 15, 2009 Report Share Posted January 15, 2009 Dude, just use ATF Type F in your tranny. It is dirt cheap and works awesome. You can get it anywhere, walmart etc. if not that then use a really nice oil like the belrays gear saver, but not regular motor oil you put in your car. Quote Link to comment Share on other sites More sharing options...
blaster2006 Posted January 15, 2009 Author Report Share Posted January 15, 2009 Dude, just use ATF Type F in your tranny. It is dirt cheap and works awesome. You can get it anywhere, walmart etc. if not that then use a really nice oil like the belrays gear saver, but not regular motor oil you put in your car. guys, i dont live in the US . thats the problem, we dont have walmart here, so your saying a normal SAE 10W-30 synthetic wont work?... at the yamaha shop all they have is a yamalube 10W- 40. they dont got 10W-30. Quote Link to comment Share on other sites More sharing options...
RollinRhino Posted January 16, 2009 Report Share Posted January 16, 2009 Avoid Yamalube for extreme cold weather, other than that I love it. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 16, 2009 Report Share Posted January 16, 2009 the only yamalube ive ever seen or used is the 2-R , i ran that for a bit before switching to supertechniplate just use 1.7 liters of atf type F its cheap as dirt, change it often and u can get it anywhere if your gona run motor oil ive been told to make sure it doesnt have "friction modifiers" because they will glaze your clutch plates and make it slip Quote Link to comment Share on other sites More sharing options...
