dajogejr Posted January 19, 2009 Report Share Posted January 19, 2009 Replied. Quote Link to comment Share on other sites More sharing options...
csrmel Posted January 19, 2009 Report Share Posted January 19, 2009 I made a drag/ trail bike. I went with cpi's, agressive dune port, pwk 35's, fzr1000 clutch, wheelie bar, stock swinger, 4 mil long rod crank. american racer sd35's on blue labels. no override, no lockup. it's pretty bad ass at the drag strip, yet has enough midrange to be fun on trails too, even technical ones. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted January 20, 2009 Author Report Share Posted January 20, 2009 I made a drag/ trail bike. I went with cpi's, agressive dune port, pwk 35's, fzr1000 clutch, wheelie bar, stock swinger, 4 mil long rod crank. american racer sd35's on blue labels. no override, no lockup. it's pretty bad ass at the drag strip, yet has enough midrange to be fun on trails too, even technical ones. Sounds like I'll be going the same route. Thanks all. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted January 20, 2009 Report Share Posted January 20, 2009 Sounds like I'll be going the same route. Thanks all. dude just fix your shit and build a separate drag bike frame up you can take your time on and still have a badass play quad. then you wont be down long either. If your goin to build a drag bike, you might as well make it a DRAG BIKE rather than a fast somewhat trail/somewhat drag. Make a rocket. Quote Link to comment Share on other sites More sharing options...
okbeast Posted January 20, 2009 Report Share Posted January 20, 2009 Sounds like I'll be going the same route. Thanks all. I would recommend a lock-up too. Alot (most) people will tell you it will be hard to shift with a lockup and no override but I don't believe this because of my 1st hand experience. I have a 4mil cub and dune/drag it. Got a +6 arm, which is still great in the trails or sand with some v-paddles. It's almost a handful with the +6 in the sand and with 10 paddles but definitely rideable, and I can still hand out some losing cards on the strip. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted January 20, 2009 Report Share Posted January 20, 2009 dude just fix your shit and build a separate drag bike frame up you can take your time on and still have a badass play quad. then you wont be down long either. If your goin to build a drag bike, you might as well make it a DRAG BIKE rather than a fast somewhat trail/somewhat drag. Make a rocket. Purpose built bike...I agree. If you plan on drag racing, get an override. You simply can not pull a clutch and shift gears as quickly as you just click up to shift, it's physically impossible. Dunable overrides are damn near bullet proof...ask anyone that has used an override that either play drag races or drag races all the time, once you go override you will NEVER go back to a normal shifting bike.... I ruins all other bikes you drive after...promise. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted January 20, 2009 Report Share Posted January 20, 2009 If you plan on drag racing, get an override. You simply can not pull a clutch and shift gears as quickly as you just click up to shift, it's physically impossible. Dunable overrides are damn near bullet proof...ask anyone that has used an override that either play drag races or drag races all the time, once you go override you will NEVER go back to a normal shifting bike.... I ruins all other bikes you drive after...promise. duneable override = money well spent Quote Link to comment Share on other sites More sharing options...
njbanshee Posted January 22, 2009 Report Share Posted January 22, 2009 I spent thousands of dollars before i finally made it an all out drag bike. I only did this when i got my girl a 400 ex. That way i could still go riding anywhere. You will spend a small fortune unless you decide what you want. Good luck. Quote Link to comment Share on other sites More sharing options...
devin4491 Posted January 23, 2009 Report Share Posted January 23, 2009 dude just fix your shit and build a separate drag bike frame up you can take your time on and still have a badass play quad. then you wont be down long either. If your goin to build a drag bike, you might as well make it a DRAG BIKE rather than a fast somewhat trail/somewhat drag. Make a rocket. yeah thats exactly what im goin through right now.. workin out pretty good. and its comin along alot faster than i thought. and im learnin a shit-ton. best way. i have 2 other play bikes (both ltr's) and i've finally decided on just building an all out drag bike... Quote Link to comment Share on other sites More sharing options...
