couple of questions
how does everyone here rate Vito's products? Good? i was about to order his Hemi 2 head with domes for 249......is that price reasonable?
before i install my chariot timing advance i was wanting to lighten the flywheel, is this something i can do myself if so what methods have u used? drilled holes etc..... do the holes need to be evenly spaced so it wont vibrate or what? or should i just have it done..... thanks
it needs to be machined and balanced, imo
send ur flywheel off to a shop that nows how to do them.. if they are done wrong ,they will come apart and mess some shit up !!!!!!!!
as for the head... id actually look into a noss head. u can run stock studs, and noss heads are nice and he also cuts custom domes if u ever need them.
ok ill get a noss head......i dont wanna fool with pulling studs....... i got about 250 unexpected dollars today and was looking at a head with 21cc domes (93 octane) or some v force 3 reed cages n reeds...... which would be the best bang for the buck?? im do both soon.... also 21cc domes is the lowest i can go with 93 octane right?
If you are close to sea level, 21cc would be my recommendation with 93 octane. If you order the Noss Head, be sure and mention your BHQ membership if you call or use BHQ for the coupon code on the web site. It will save you 10%
-David
