Hey buddy speaking of the axle have you seen the 14 bolt conversions they do so you can run a 14 bolt in the front like you were talking about with the 44? If you build it right they're pretty cheap and stand up alot better than the Dana 60
No i have not seen that. I started to build a front 14 bolt a couple of years ago then we sold then pickup and i have never gone back to the project. The only problem with the 14 bolt is you can only run a gear as low as a 5.13 and the housing hangs so low but you can trim the housing.
  • 1 month later...
[img=http://i451.photobucket.com/albums/qq233/chevy7944/0215091541.jpg]
Well we have made a little more progress on the S-10 so i thought i would share the pic i took the other night. LOL it is cool to fire up an S-10 and have it shake the whole shop when it is running.
Edited by motor builder
LOL i have no idea what i did to make the pic like that but hope you guys can see it ok.
If you reach your 550hp goal, 4.88s will be just right. I ran 44 uncut boggers with 410s and 600hp, and that was in a full size truck. I ran a beefed up 44 in the front with a 205 in the middle and a 14 bolt factory posi out back. If all your going to do is mud race, research the beefed up 44. It saves you quite a bit of weight and not to mention ground clearance. Plus it will only be $600 fully built as opposed to $1k for a stock 60. Cool project man!!
I would never run a dana 44 front with 44" boggers. Unless you like changing axles. Dana 60 fronts are all over the place. Anyware between $400- $750.
Bad ass.
Thanks man it has been a lot of fun to build so far.
It has a 60 in the front i have no intentions of putting a 44 in one with this big of tires and this much motor.
  • 1 month later...
Well we finally got it all done and took it out for its first test yesterday. It is just scary how much power this thing has with that big block in it. Here are a coupleof more pics of the completed project. let me know what you guys think.
LOL here is one more pic for you guys. My buddy was following us in his mog and he had to prove to us how bad ass it was and he got it stuck.
  • 3 weeks later...
We took the S-10 out on the sand for the first time last weekend. This thing goes like a bat out of hell. It is a ton of fun to drive! Here is a short little vid of one of the hill climbs. We went up every dune in two wheel drive.
http://vids.myspace.com/index.cfm?fuseacti...ideoid=55417440
  • 3 weeks later...
Finally got the chance to take the s-10 out in the mus the other day. Here are a couple of pics.
