oldschoolhuffy Posted January 7, 2009 Report Share Posted January 7, 2009 how u guys doing i have used this forum for awhile now but just never really had any questions to ask but i just took off my nerfbars a couple days ago because a bolt had seemed to have snapped when i took it off i noticed that the threads to the one bolt were cracked and were not holding the bolt i was wondering if this has happened to anyone else and if anyone knows a way to fix the threads Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 7, 2009 Report Share Posted January 7, 2009 which one is it? either way, it'll need a new one welded in, but if it's th right front, it'll just be easier cus you may be able to weld and retap Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 7, 2009 Report Share Posted January 7, 2009 i stripped bot my peg holes on one side, i just ran the next size larger tap through worked like a charm Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 7, 2009 Report Share Posted January 7, 2009 i stripped bot my peg holes on one side, i just ran the next size larger tap through worked like a charm a cracked sleve will expand when torqued allowing the bolt to slip Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted January 7, 2009 Report Share Posted January 7, 2009 I was able to rethread mine as well, thats been two years and no problems yet. Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted January 7, 2009 Report Share Posted January 7, 2009 a cracked sleve will expand when torqued allowing the bolt to slip didnt realize he cracked the whoel thing my friend did that and had 2 new cylinders welded in by the guy down the street, tapped them and its held up fine ever siunce Quote Link to comment Share on other sites More sharing options...
austin Posted January 8, 2009 Report Share Posted January 8, 2009 Ive had mine break clean off, only holding on by one bolt. Just cleaned it up and welded er back on. That was about 2 years ago, no probs since. Quote Link to comment Share on other sites More sharing options...
