blaster2006 Posted January 6, 2009 Report Share Posted January 6, 2009 (edited) well, i was told that it needs to be like tall enough, in the pic the threads looked big enough, but it says 14mm and 18mm, will that fit in a BR8ES spot for the shee? basically if i buy that will it fit in the shee? http://cgi.ebay.com/ebaymotors/Yamaha-Wave...%3A1|240%3A1318 Edited January 6, 2009 by blaster2006 Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted January 6, 2009 Report Share Posted January 6, 2009 well, i was told that it needs to be like tall enough, in the pic the threads looked big enough, but it says 14mm and 18mm, will that fit in a BR8ES spot for the shee? basically if i buy that will it fit in the shee? http://cgi.ebay.com/ebaymotors/Yamaha-Wave...%3A1|240%3A1318 i believe the banshee is a 14mm so it should work but i would lookit up in the manual to double check Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 6, 2009 Report Share Posted January 6, 2009 Yea you can use that testor but it wont be as accurate. You will have to use that long adaptor threaded on to the hose. Well that hose has a passage drilled in it and a little chamber. I had one like that and the adaptor held 3cc's of fluid. So that is like adding 3cc's to the combustion chamber volume. The best testers have a seperate hose for ever style of spark plug. That way they can have the schrader valve in the verry tip. josh Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 7, 2009 Report Share Posted January 7, 2009 yah the br8 is 14 mm. the tip has both sizes in one, i use the same one. that adapter is only for reach- like sticking it in a v8 or v6, where you barely have room to grab the spark plug Quote Link to comment Share on other sites More sharing options...
RollinRhino Posted January 7, 2009 Report Share Posted January 7, 2009 That looks like a good deal. :thumbsup: Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted January 7, 2009 Report Share Posted January 7, 2009 did you get it? Quote Link to comment Share on other sites More sharing options...
