tidos76 Posted February 15, 2009 Report Share Posted February 15, 2009 the leds i got from egay. 5 for 17 i think linky The rest i got from the led supply. they sell everything but the leds were cheaper on ebay ledsupply Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 16, 2009 Report Share Posted February 16, 2009 Can you do a full write up on it with pics? Quote Link to comment Share on other sites More sharing options...
tidos76 Posted February 16, 2009 Report Share Posted February 16, 2009 (edited) it will be a lil bit before i can. The one completed light is all siliconed and epoxied together. when i get some $ i'll order the rest of the leds and such i need and do a writeup with the other light. I for the most par followed this. i only used 2 switches. on/off and hi/low, maki everytin fit was the ard part. there is 2 switched a buckpuck, heatsink, 4 leds, and 4 lenses crammed into that lil light. its a very tight fit. Edited February 16, 2009 by tidos76 Quote Link to comment Share on other sites More sharing options...
poorboystoys Posted February 18, 2009 Report Share Posted February 18, 2009 I am getting a high powered stator, either RS or electrolux.. I wanted to know of a good set of lights that wont cost one of my nuts!I think Im gonna convert to DC and add a battery also. If I install, do I need to constantly charge the battery using an outlet when Im not riding? Thanks! i have no idea if this will help but here a picture of my bike with no battery and these light up the night its has some type of box on the left side of the frame too the starter Quote Link to comment Share on other sites More sharing options...
AKheathen Posted February 18, 2009 Report Share Posted February 18, 2009 ok, so i baught the walmart lights, like 4 different kind. wanted to keep high and low, and that look that makes everyone call her "R/C" i went with the bullet lights, and kept the one 50watt flood, and replaced the other with a 20watt spot i already had for accents in my room. then i installed the "hid" look ones for highs. i figured that you usually only need high beams when going fast at high rpm's so i left the bulbs for now. the bullets light the muthafuckin world. just thaught u might like to know Quote Link to comment Share on other sites More sharing options...
tidos76 Posted February 20, 2009 Report Share Posted February 20, 2009 well i ordered the struff to do my other light with leds. I'll do a writeup and get a parts list hopefull within the next few weeks. Quote Link to comment Share on other sites More sharing options...
Powerstroke Posted February 20, 2009 Report Share Posted February 20, 2009 well i ordered the struff to do my other light with leds. I'll do a writeup and get a parts list hopefull within the next few weeks. :thumbsup: Can't wait to see the write up very interesting tread. Quote Link to comment Share on other sites More sharing options...
hollisatp Posted February 21, 2009 Author Report Share Posted February 21, 2009 well i ordered the struff to do my other light with leds. I'll do a writeup and get a parts list hopefull within the next few weeks. yeah me too!!! LEDs are bright but use alot less power.. Id love to hook a set up under my front bumper for night riding in the dunes... hate not being able to see the ground when Im topping a razor back.. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 21, 2009 Report Share Posted February 21, 2009 hate not being able to see the ground when Im topping a razor back.. You have to open your eyes! :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) both stators are POS, go for the ricky stator though. The Ricky Stator's issues can be solved by upgrading the hardware it comes with. If it has philips head screws replace them with some higher grade allenhead bolts (mounting the stator to the plate). The stator itself should be fine if you get his newest version, and it is very easy to float the ground. Unfortunately a battery has nothing to do with how large of a stator you need. Every time you are not on the throttle you will be draining the battery... having a higher output stator and flywheel DOES help and I would certainly get both if your changing to HIDs. The stock stator and flywheel will only power about 70-75 watts of lighting properly, beyond that you will run into issues. If your converting to DC then subtract even more... nice job on the luxeon conversion, however that would jsut not be enough light for me. However if you find a way to do a conversion using Cree XRE's let me know! I have been running luxeons for several years, they are ok, but not as efficient as HID's so I don't use them for headlights. I know how bright a Quad Luxeon flashlight is as I made one that runs off Lithium batteries, they are quite suprising with XRE's aproaching HID efficiency and not having the warm up / constant current issues they would be alot less problematic on a banshee or other small vehicle with limited power source. Edited February 24, 2009 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 24, 2009 Report Share Posted February 24, 2009 Just found out I can get these from a buddy of mine. I went in and checked them out. Draws .75 amps. 800 lumens of light. (has a 10 watt led in it) come in flood, spot, and euro beam patterns. Pretty in-expensive and super rugged construction. They inter lock on each other and come with a mounting base that can be put in the stock headlight location on a banshee. I saw one today in his office, and it was as bright as the hid's he sells. I am sold on them. I think I am gonna run either 3 or 4 of them. If anyone wants them, pm me. He told me they drove a backhoe over one 3 times and it never broke, and the light in it still works. It also vibration tested ok at 20 g's. Specifications Dimensions 2" x 2" x 2" Diameter 2" Weight .25 lbs Mounting Depth 1" Amperage Draw .75 @ 12 Volts Input Voltage 9 - 60 Volts DC Housing Die-Cast Aluminum Number of LEDs 10 Watt LED Housing Black Lumens 800 Watts 10 Beam Pattern Flood, spot, euro Warranty Lifetime Limited Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted February 24, 2009 Report Share Posted February 24, 2009 Quote Link to comment Share on other sites More sharing options...
tidos76 Posted February 24, 2009 Report Share Posted February 24, 2009 those are pritty sweet. whats the $?and the aluminum case means it can be polished up! lol Quote Link to comment Share on other sites More sharing options...
hollisatp Posted February 24, 2009 Author Report Share Posted February 24, 2009 You have to open your eyes! :yelrotflmao: ha ha.. I find that it takes a second to adjust to the low light under the quad at night.... just for safety ya know.. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) as bright as 35 watt HID's? I call Shens, what LED's are those using inside? What kinda of circuit and how efficient is it? depending on internals I might be interested! Edited February 24, 2009 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
