sheerider1026 Posted January 6, 2009 Report Share Posted January 6, 2009 ok. i have smoke a brand new clutch in one summer.. i am switching over to a lockout with fzr1000 fibers, but i am resuing the clutch steals... should i use some fine sandpaper to ruff up the steels a little?? they are very glazed over.. what should i do? usem the way they are or ruffem up a little?? Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted January 6, 2009 Report Share Posted January 6, 2009 Just get new ones, they are cheap... Quote Link to comment Share on other sites More sharing options...
firebanshee Posted January 6, 2009 Report Share Posted January 6, 2009 ok. i have smoke a brand new clutch in one summer.. i am switching over to a lockout with fzr1000 fibers, but i am resuing the clutch steals... should i use some fine sandpaper to ruff up the steels a little?? they are very glazed over.. what should i do? usem the way they are or ruffem up a little?? I have deglazed my steels with sand paper or a finishing pad on my die grinder and it worked good. Do you have and override trans? Lockups make your bike shift hard without an override. Have you tried heavy springs in your clutch? and also if you use the wrong gear oil it can make your clutch slip. I like type F trans fluid it has anti slip agents built into it. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted January 6, 2009 Author Report Share Posted January 6, 2009 yes. it does have an overide in it now.. i am just now switching over to the overide and lockout.. the steals are not that old at all.. just thought i could sandem a little and be good to go.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 6, 2009 Report Share Posted January 6, 2009 Lightly bead blast them. Quote Link to comment Share on other sites More sharing options...
