tonyown Posted January 5, 2009 Report Share Posted January 5, 2009 here are some pics of my job did it today tell me what you think good or bad I want to know! Quote Link to comment Share on other sites More sharing options...
spurdy Posted January 6, 2009 Report Share Posted January 6, 2009 (edited) Are you taking material off to the outside of your lines or to the inside? And how did you come up with the lines? They should match the contour of your jugs. SP Edited January 6, 2009 by spurdy Quote Link to comment Share on other sites More sharing options...
tonyown Posted January 6, 2009 Author Report Share Posted January 6, 2009 I take material off inside the black line I stop at the line... I matched the gasket to my jugs and then wrote the line with my gasket on the base and I did a black line outside Quote Link to comment Share on other sites More sharing options...
firebanshee Posted January 6, 2009 Report Share Posted January 6, 2009 Looks good to me if they match your jugs. :cool: Quote Link to comment Share on other sites More sharing options...
peterlocal22 Posted January 6, 2009 Report Share Posted January 6, 2009 here are some pics of my job did it today tell me what you think good or bad I want to know! looks great Quote Link to comment Share on other sites More sharing options...
spurdy Posted January 6, 2009 Report Share Posted January 6, 2009 I take material off inside the black line I stop at the line... I matched the gasket to my jugs and then wrote the line with my gasket on the base and I did a black line outside Yep, if it matches your jugs you should be fine. I have also seen where guys rough up the cavity the crank spins in to help with fuel atomization just like you don't want anything smooth in the intake, transfers, or where you do you case matching. SP Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted January 6, 2009 Report Share Posted January 6, 2009 Looks good, what did you use to do it? Why would you rough up the area where the crank spins? Quote Link to comment Share on other sites More sharing options...
tonyown Posted January 6, 2009 Author Report Share Posted January 6, 2009 used a dremel and lot of time :happy: I'm gonna do the other side as soon as I can so I can put the engine together before the end of the winter :biggrin: Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted January 6, 2009 Report Share Posted January 6, 2009 you used the budweiser ! looks great ! Quote Link to comment Share on other sites More sharing options...
AKheathen Posted January 7, 2009 Report Share Posted January 7, 2009 used a dremel and lot of time :happy: I'm gonna do the other side as soon as I can so I can put the engine together before the end of the winter :biggrin: all that white sand; i thaught u were using a stone Quote Link to comment Share on other sites More sharing options...
tonyown Posted January 7, 2009 Author Report Share Posted January 7, 2009 you used the budweiser ! looks great ! Yea a lot of people use coors light here (4%) but i prefert the taste of some good 5% bud or black or labatt 50 or some other good ones :biggrin: Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted January 7, 2009 Report Share Posted January 7, 2009 Looks like you did a good job. But, what do you gain from porting the cases? thanks Quote Link to comment Share on other sites More sharing options...
MarineNYC Posted January 7, 2009 Report Share Posted January 7, 2009 Same question. Whats the point? Quote Link to comment Share on other sites More sharing options...
tonyown Posted January 7, 2009 Author Report Share Posted January 7, 2009 Better and more flow Quote Link to comment Share on other sites More sharing options...
