Top End
shogs
I'm very close to ordering a new top end and had a few questions. I was wondering if you guys were me would you bore your cylinders or just check them out and rebuild with stock bore? I hear sometimes boring makes the reliability a little bit worse. Also is this kit (link at bottom) all i'm going to need for a top end and is it a reasonable price? I've never done a top end before and wanna just jump in to it. Someone offered to help as well so it makes me want it even more. Also while I am talking about my top end I have a question about my right cylinder. When I started it today hot air and a little bit of smoke blew out my right pipe and only room temperature smoke out of my left pipe. Could this be my reeds or is it most likely a piston problem? Thanks for the help in advance.
http://cgi.ebay.com/ebaymotors/Wiseco-Pist...sQ5fAccessories
Not sure why you want to spend more money as we have the Holliday special going on for only 155 in our sig. Need to have your cyls. looked at to see if they need bored or not. Sounds like your carbs may need synced.
I'm running a 2into1 so that isn't the problem and the carbs were synced before I took them off. I think its a problem with a gasket or seal thats broken. Is the top end special that you guys have everything i'll need? And how soon can you ship it!? :biggrin:
Should be . Tomorrow soon enough?
