lt1bird Posted December 31, 2008 Report Share Posted December 31, 2008 Who makes a long clutch pusher.....I have a lockup clutch on the end....the boss pusher cannot be adjusted as the shaft is very short....more for a stock cutch setup... Where to buy the longer pusher as well..... Thanks!!! Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 31, 2008 Report Share Posted December 31, 2008 I run a cascade pancake with my direct drive setup. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted December 31, 2008 Report Share Posted December 31, 2008 I have a boss pusher with a direct drive lockup and aftermarket clutch and got it adjusted just right that it works fine. Just a pain in the ass to settup. You can go to your local nut and bolt dealer like a Fastenal company and get that same bolt longer just make sure it's the same grade. But if you lock the nut on the one they gave you at the very very end carefully lol it works. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 31, 2008 Report Share Posted December 31, 2008 huh, never heard of this problem before.. make sure you let us know of the fix so we can have the info in case it comes up again. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted December 31, 2008 Author Report Share Posted December 31, 2008 (edited) Cant say it's a big problem.....Just looking at it im saying i want one better....Dont like the Boss one.... Guess if i had a wrench that was 90 degrees on the end to fit in there. Im not sure how it can be done with the lockup in place using the Boss pusher??? Doesnt look like that cascade sticks out to much either...... doesnt anyone make a longer one that extends out made for lockup clutch setups? Edited December 31, 2008 by lt1bird Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted January 1, 2009 Report Share Posted January 1, 2009 Im pretty sure i have a long one. Ha that sounds cool uhhh i mean bad. lol Give me a call Friday afternoon when im in the shop and i will measure the 2 different adjusters and see. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted January 1, 2009 Author Report Share Posted January 1, 2009 will do..... Quote Link to comment Share on other sites More sharing options...
FireHead Posted January 1, 2009 Report Share Posted January 1, 2009 Im pretty sure i have a long one. Ha that sounds cool uhhh i mean bad. lolGive me a call Friday afternoon when im in the shop and i will measure the 2 different adjusters and see. I also have a long one, but I made the push rod out of hardened drill rod. I switched over to an adjuster setup from Cascade, and didn't need the longer push rod anymore. :geek: Quote Link to comment Share on other sites More sharing options...
J-Madd Posted January 1, 2009 Report Share Posted January 1, 2009 Cant say it's a big problem.....Just looking at it im saying i want one better....Dont like the Boss one.... Guess if i had a wrench that was 90 degrees on the end to fit in there. Im not sure how it can be done with the lockup in place using the Boss pusher???Doesnt look like that cascade sticks out to much either...... doesnt anyone make a longer one that extends out made for lockup clutch setups? A buddy of mine bent the boxed end of a wrench to about 90 degrees just for that reason. Works like a charm. Quote Link to comment Share on other sites More sharing options...
docjcwatson Posted January 1, 2009 Report Share Posted January 1, 2009 A buddy of mine bent the boxed end of a wrench to about 90 degrees just for that reason. Works like a charm. X2. This is what my builder told me to do also. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted January 1, 2009 Author Report Share Posted January 1, 2009 SO heat the wrench with a torch and bend it? Quote Link to comment Share on other sites More sharing options...
