dirtydownunder Posted December 30, 2008 Report Share Posted December 30, 2008 (edited) hey fellaz, I noticed my chain had a bit of slack and to closer inspection i saw that the round bigger middle chain guide looks to be flapping around, does this guide have a bearing in it thats broken or do they just flap and spin around ?. thanx. Edited December 30, 2008 by dirtydownunder Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 30, 2008 Report Share Posted December 30, 2008 The stock one on the swingarm? Quote Link to comment Share on other sites More sharing options...
Misssppelllleddd Posted December 30, 2008 Report Share Posted December 30, 2008 The one on the swing arm doesn't have any bearings at all. If it moves alot you might want to replace it. The stock one is pretty thin and I'm not a big fan of it so I bought an Cascade Chain slider from RMATV. Much thicker than stock and I would prefer that one because it helps guide the chain as well. The upper and lower rollers have bearings. I would suggest going aftermarket on those as well. I used the 'power lip' one from TMD. That one works pretty well. As for the top one...I've never seen any markings on it from the chain. Hope this helps. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted December 30, 2008 Author Report Share Posted December 30, 2008 yeh snopczynski the one on the swingarm (swingarm bolt goes thru it). misssppelllleddd yeh all the guides are stuffed, ill tighten that chain up and get some new guides. Thanx. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 30, 2008 Report Share Posted December 30, 2008 The one on the swing arm doesn't have any bearings at all. If it moves alot you might want to replace it. The stock one is pretty thin and I'm not a big fan of it so I bought an Cascade Chain slider from RMATV. Much thicker than stock and I would prefer that one because it helps guide the chain as well. The upper and lower rollers have bearings. I would suggest going aftermarket on those as well. I used the 'power lip' one from TMD. That one works pretty well. As for the top one...I've never seen any markings on it from the chain. Hope this helps. Ditto on what he said then. Quote Link to comment Share on other sites More sharing options...
