Big_Dave Posted December 29, 2008 Report Share Posted December 29, 2008 can you run a +4 mm stroke- +5mm longrod crank without cylender spacers? is there anyone that had the ports redone and a head to accept this mod... or is this impossible? Quote Link to comment Share on other sites More sharing options...
Paddleboy Posted December 29, 2008 Report Share Posted December 29, 2008 no you either need the spacer or domes to fit the extra stroke Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 29, 2008 Report Share Posted December 29, 2008 yes, that is the preferred method. spacer plate setups are junk. you going to have motor work done? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted December 29, 2008 Report Share Posted December 29, 2008 It's absolutely possible. I build them all the time and never run spacers. You will need to have your stock head rechambered or purchase a billet head and stroker domes. With the 115mm rods you will have to run the 795 series Wiseco pistons. Quote Link to comment Share on other sites More sharing options...
Big_Dave Posted December 29, 2008 Author Report Share Posted December 29, 2008 (edited) ok, better scenerio... lets say i had the above explaned setup and stroker domes in a aftermarket head, what would need done to the ports, to correct for port timing? Edited December 29, 2008 by Big_Dave Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted December 29, 2008 Report Share Posted December 29, 2008 ok, better scenerio... lets say i had the above explaned setup and stroker domes in a aftermarket head, what would need done to the ports, to correct for port timing? Are you planning on doing your own port work? The floors need lowered @2mm to match the stroke. The amount they are raised will depend on what pipes you're running, your weight , elevation and purpose of the bike. Quote Link to comment Share on other sites More sharing options...
Big_Dave Posted December 29, 2008 Author Report Share Posted December 29, 2008 hahaha i caught myself being simple... 2mm lower ports would make sence on a 4 mm storker. :shrug: Ill level with yins. heres hopin, but my fantasy DRAG setup would be 4mill hot rods crank with wiseco stroker pistons runnin on VP c12, 34 mm pwks, lightend flywheel, adjustable ignition plate, coolheads billet head... or F.A.S.T billet head with 18mm stroker domes, and shearer sb inframes or toomey t5's. more than likly toomeys because i can have them for a few greens less than shearers... budgeted around $1000 for now not including pipes. Does ANYBODY have a similar setup or know if its gonna build some power. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted December 29, 2008 Report Share Posted December 29, 2008 hahaha i caught myself being simple... 2mm lower ports would make sence on a 4 mm storker. :shrug: Ill level with yins. heres hopin, but my fantasy DRAG setup would be 4mill hot rods crank with wiseco stroker pistons runnin on VP c12, 34 mm pwks, lightend flywheel, adjustable ignition plate, coolheads billet head... or F.A.S.T billet head with 18mm stroker domes, and shearer sb inframes or toomey t5's. more than likly toomeys because i can have them for a few greens less than shearers... budgeted around $1000 for now not including pipes. Does ANYBODY have a similar setup or know if its gonna build some power. It's all going to depend on the portwork. But yes, with the right porting would build some nice power. Keep an eye on the for sale section, all of the parts you could want for the build will show up there from time to time. Quote Link to comment Share on other sites More sharing options...
Big_Dave Posted December 29, 2008 Author Report Share Posted December 29, 2008 Thanks man Quote Link to comment Share on other sites More sharing options...
MikeNick Posted December 29, 2008 Report Share Posted December 29, 2008 budgeted around $1000 for now not including pipes. I think your going to need to increase your budget a tad bit. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted December 29, 2008 Report Share Posted December 29, 2008 I could help you get to a pretty good start but is an alky setup. I am going to list a complete +4 stroke + 5 long rod crank that is welded w/TZ and max load bearings, drag ported by Patriot racing(approx 90 horse) top end w/RK Tek head w/cut domes, pistons, rings, etc. If anyone is interested, shoot me a PM. Quote Link to comment Share on other sites More sharing options...
278 Posted December 29, 2008 Report Share Posted December 29, 2008 I could help you get to a pretty good start but is an alky setup. I am going to list a complete +4 stroke + 5 long rod crank that is welded w/TZ and max load bearings, drag ported by Patriot racing(approx 90 horse) top end w/RK Tek head w/cut domes, pistons, rings, etc. If anyone is interested, shoot me a PM. Sounds like your going bigger lol. As far as this set up if you choose to buy it you can switch out the domes to accomedate whatever fuel you wanted to run Quote Link to comment Share on other sites More sharing options...
sheefreak Posted December 29, 2008 Report Share Posted December 29, 2008 Sounds like your going bigger lol. As far as this set up if you choose to buy it you can switch out the domes to accomedate whatever fuel you wanted to run Absolutely. Anyone reputable could cut you some domes to run race fuel. As a matter of fact, I have a spare set of domes that is not cut for the 4 mill that should be able to be cut to spec. That would have to be verified. I will also have some other goodies for sale like Shearer small bore small flange silenced chrome OOF pipes, but I have to make some final decisions before listing. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 29, 2008 Report Share Posted December 29, 2008 I think your going to need to increase your budget a tad bit. always allow for about another grand on a drag bike. there will be shit you for got or just wanna add cuz its blingin. :biggrin: Quote Link to comment Share on other sites More sharing options...
tedd1 Posted January 1, 2009 Report Share Posted January 1, 2009 always allow for about another grand on a drag bike. there will be shit you for got or just wanna add cuz its blingin. :biggrin: Specifically, a lock-up clutch and an override tranny.... :geek: Quote Link to comment Share on other sites More sharing options...
