Rear Bearings
Pyrojunky619
Anyone know the easiest way to get the old ones out of a stock carrier?
Also anyone got any info on the grease zerk mod or the stock carrier ?
A punch and a hammer usually work well to take the bearings out.
To put the grease zerk in you need to take the inside seal out of the new bearings when you put them in the carrier also you need to drill a hole some were in the middle of the carrier it is up to you were you want it then tap the hole for a grease zerk and just screw one in it.
