CHARIOT HEAD INSTALL
330 R killer
No you dont use the stock head gasket. There should be O rings to seal it up. 1 O ring on each dome, Then a 2 o rings around the head where it seals against the cylinders, and 2 o rings down in the head shell to seal the shell to the top of the domes.
Use some vasoline on the orings to hold them in place. That way they are not falling out.
I would also take the fitting of the back of the head that hooks to the radiator hose. That way you can put the head on and not fight the rear radiator hose and trying to keep the o rings from falling out at the same time.
OK THANK YOU FOR HELPING ME BRO..
CAN SOMEONE PLEASE HELP ME OUT,I AM TRYING TO INSTALL MY NEW HEAD TOOK OFF STOCK HEAD TODAY.DO I LEAVE ON THE STOCK HEAD GASGET??????? WERE DO THE O RINGS GO SOME ONE PLEASE HELP
ok I USE O RINGS ON THE DOMES 2 OF THEM THEN I USED THE O RINGS ON TOP OF THE HEAD WERE THE DOMES SIT 2 LITTLE ONES SO WHY DO I HAVE ONE MIDDLE AND TWO SMALL ONES LEFT OVER..AM I MISSING SOMETHING??? WHY SO MANY O RINGS????
there are older sets of domes that used the two left over orings. They put those in there just incase thats the kind you have so there are no issues.
I have two chariot cool heads and one of the o-rings fits in the back, carb side, of the head where the water hose connects to the head fitting. If you look back there you will see two allen screws, unscrew them, take the fitting off and put one of the o-rings on. You should only have one extra o-ring when done.
my chariot has two leftover orings for the old style head. if you have only one left over something is wrong
