278 Posted December 20, 2008 Report Share Posted December 20, 2008 So now that I have found I am going to have to run higher octane fuel... Im considering upgrading, I kind of want to split the cases again to do a real nice polish job so... How much is a stock true/welded crank, Wiseco Pro-lite pistons, and aggressive trail ported cylinders worth I was thinking around 500-600 (hopefully) beings the fact that all these parts havn't even been ridden on yet. Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted December 20, 2008 Report Share Posted December 20, 2008 I'm confused..where dose the 4mill part come in at? Are you wanting to upgrade from what you have now (what you listed above)? I would say around 4-500 for what u asked.Stock/welded cranks don't go for much maybe 110 give or take 10 and well,you can figure the rest out Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted December 20, 2008 Report Share Posted December 20, 2008 Well...lol, the crank will be worth around $150(given it has new bearings maybe a little more) and the cylinders with new bore/pistons will be worth $250-$300. Your porting as it was a trail port may be coservative enough to be redone for the 4mil stroke. A new hotrods 4mil crank will run right around $450, 795 pistons will run @$170, seals will be $35, domes $75 and gaskets $45 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 20, 2008 Report Share Posted December 20, 2008 i see no reason why you cant get 600 out of a good running setup. itll cost someone more in time and money just to do a rebuild and have their cyls ported. Quote Link to comment Share on other sites More sharing options...
278 Posted December 20, 2008 Author Report Share Posted December 20, 2008 Well...lol, the crank will be worth around $150(given it has new bearings maybe a little more) and the cylinders with new bore/pistons will be worth $250-$300. Your porting as it was a trail port may be coservative enough to be redone for the 4mil stroke. A new hotrods 4mil crank will run right around $450, 795 pistons will run @$170, seals will be $35, domes $75 and gaskets $45 Yeah I'm considering upgrading from stock to 4mil... Not for sure but its an idea Im throwing around. Most likely Im going to stick with my setup for a bit and work on the rest of the shee, just wanted to get an idea. Havn't seen you on here in a while Brandon except for last couple days, Hope everything is going well. Quote Link to comment Share on other sites More sharing options...
