Troubledsol Posted December 19, 2008 Report Share Posted December 19, 2008 I was just curious after doing some searching if anyone is running larger than a 35PWK for a single carb I just got a deal on a bored 39mm PWK and was going to use that and put my 35 PWK on the wifes Blaster after I port it (Port Logic Templates before anyone asks) Also what is the throttle cable I should use for the Blaster with a PWK Thanks Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 19, 2008 Report Share Posted December 19, 2008 im not a fan of single carb setups but im sure the 39 will be fine. as far as throttle cables go, not really sure. im not familiar with the stock cable on blasters. you could quite possibly use a throttle cable off a dirt bike like the cr250 as most of them use keihin carbs. just not sure if the throttle end would match up since the bikes are twist throttle and blaster is thumb. Quote Link to comment Share on other sites More sharing options...
rubberneck Posted December 19, 2008 Report Share Posted December 19, 2008 You could use a cable off of and ATC 250R. or fourtrax 250r they had either PJs or pwks i believe and thumb throttles. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 19, 2008 Report Share Posted December 19, 2008 I work on two bikes with single carbs still. They run 36mm and 38mm lectrons. Quote Link to comment Share on other sites More sharing options...
Troubledsol Posted December 19, 2008 Author Report Share Posted December 19, 2008 Snop how do they run I love my 35 PWK it was on the shee when I got it though a few guys here talked me into trying stockers again so I bought a cable and a jet kit and all the other stuff I needed I didnt like it at all we tinkered with it for a while and never could get it right and at its best time it was a pig down low I am looking to put this 39 PWK on and do the Port Logic stage 3 and see how she runs If anyone knows for sure what cable to use that would be great Thanks all Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 20, 2008 Report Share Posted December 20, 2008 They like it. I swapped one of the guys kids bike back from a 35mm pwk to twin tm 28mm mikuni flatslides and it definitely is faster now then it was before. He is also running pro circuits now, and we got rid of his ptr mids. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 20, 2008 Report Share Posted December 20, 2008 dual carbs will always make more power than a single carb. Quote Link to comment Share on other sites More sharing options...
Troubledsol Posted December 21, 2008 Author Report Share Posted December 21, 2008 I ride mostly tight woods thats why I am liking the single though over the summer I may try and dig up some duals and try them again Thanks for the input Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 21, 2008 Report Share Posted December 21, 2008 I ride mostly tight woods thats why I am liking the single though over the summer I may try and dig up some duals and try them again Thanks for the input 1. With the size of carb you chose it will probably make less low end power compared to 28mm duals with your mods. 2. Even if you ran a smaller carb like a pwk 35mm setup for the single, you probably wont notice a difference in low end power over a good set of 28mm carbs. Quote Link to comment Share on other sites More sharing options...
