Trail riding and long straights
Im rebuilding my stock she into a trail moster.
I have a couple questions for the gurus
I'm going to have the topend bored to .40 and a mild port
Have vforce 3 reeds
I do mostly dirt trails and open dirt roads (NY)
I will be buying a cool head or noss head or one of those companies
I would like to know what size carbs I should get and what size domes to make some awesome power
I dont want to run race gas but want to run 93.
Thanks!
I like smaller carbs on trail motors. So my choice would be 28 PWK's.
But... what do I know.. I have a drag bike in my sig... :yelrotflmao:
You forgot to ask if these were special or magical trails...found only where he rides....
Most competent engine builders will tell you keep the carbs small for trail motors...even with some stout porting.
28PWKs or 30mm OKO knockoffs would be my choice as well.
Hey update
I have fmf fatty sst pipes and powercoreII silencers. I do run 93 all the time now. I havnt got the vf3 reeds yet but i dont need them? what would you recommend stocks? Ill trying to make a list of what i should get
To get:
21cc domes is a deff
Timing plate
carbs (28 or 30)
what else
Hey update
To get:
Timing plate
carbs (28 or 30)
what else
If you are ported, you might as well get the VF3s...but you don't NEED them.
Buy a head...if it's Pro Design, you'll need automotive loctite that's capable of withstanding the motor temps, and some vaseline for the O-Rings. You will also need a flywheel puller to install the timing plate.
Grab one of the boss 1 piece billet intakes with the built in cross over. They look great and will keep your carbs up and outta the way of the clutch lever. I just installed a set of pwk 28's (trail machine) on stock intakes and the left one lays on the clutch lever. I just ordered a boss intake myself.
I hear Pro Circuits are the way to go for the best low/mid pipe. I plan on grabbing a set. i currently run DG's and they work well also.
Run your stock reed cages and some dual stage reeds instead of the v3's
boyesen or carbon tech reeds on stock cages are more then enough for your motor setup..
I've always been really happy with the boyesen dual stage power reeds. They worked really well on my Trinity TT ported motor. I couldn't tell any difference when I switched to the VF2's.. Just some food for though.
What he said. Much cheaper then the V forces to.
