vulvafan537240 Posted January 12, 2009 Report Posted January 12, 2009 when hooked up on the lights wire, does it loose any info when the bike is shut off? No it has an internal battery too. It will actually run off the internal one but it wont have the back light or the waring lights. josh x2. wire it up before the switch so its on even with the lights off Quote
hotrodbanshee Posted January 12, 2009 Report Posted January 12, 2009 Has anyone had problems with the tach not reading RPM's correctly. A buddy of mine said his will max out the tach at 1/4 trottle. Tried wirring it different ways with no luck. Quote
Invader Posted January 12, 2009 Report Posted January 12, 2009 Has anyone had problems with the tach not reading RPM's correctly. A buddy of mine said his will max out the tach at 1/4 trottle. Tried wirring it different ways with no luck. tell him he has to change the Pulses per Revolution (PPR) to 2.0 Quote
evro Posted January 29, 2009 Report Posted January 29, 2009 tell him he has to change the Pulses per Revolution (PPR) to 2.0 i've been thinking about one of these myself. i emailed a dealer and asked about the back light and warning lights and the reply stated that without a full 12 volt system (including a battery) the lights won't work. for those of you running off the stator, do your warning and back lights work? or just strictly your gauges? thanks Quote
vulvafan537240 Posted January 29, 2009 Report Posted January 29, 2009 i've been thinking about one of these myself. i emailed a dealer and asked about the back light and warning lights and the reply stated that without a full 12 volt system (including a battery) the lights won't work. for those of you running off the stator, do your warning and back lights work? or just strictly your gauges? thanks yes warning lights, backlight and gauges work. find a "hot" wire. i wired mine in to the headlight switch. before the switch so its on all the time when the shee is running. find the wire coming in to the switch, not one going out to the headlights. cant remember which color it is but its not that hard. Quote
evro Posted January 30, 2009 Report Posted January 30, 2009 yes warning lights, backlight and gauges work. find a "hot" wire. i wired mine in to the headlight switch. before the switch so its on all the time when the shee is running. find the wire coming in to the switch, not one going out to the headlights. cant remember which color it is but its not that hard. perfect. thanks for the response. i just picked up a 2000 Banshee in December and have been researching this unit after seeing it on ebay. I've had/have street bikes and sleds, but nothing like this. All of my units have tachs on them so test driving this thing with no previous riding comparison was interesting. I'll definitely get one of theses units. the temperature sensor is another huge plus for me with my limited experience on banshees. the yfz450 front shock changeover looks like a good idea too. not a huge guy but at 200+ lbs decked out, i would likely appreciate the added travel. The buddy i bought it from said the stock suspension is not terribly durable and the closer i stay to the ground, the better. Great site guys. looking forward to more mods and tips. Quote
CoreyReid Posted April 10, 2009 Report Posted April 10, 2009 anyone have any pics with their different mounting or custom brackets? Quote
Ruko Posted April 11, 2009 Report Posted April 11, 2009 anyone have any pics with their different mounting or custom brackets? Kinda like Volfan's but I had to make one fit an anti-vibe.... Quote
bansheeqc Posted April 12, 2009 Report Posted April 12, 2009 I have a vapor trailtech. I have trouble with temp gauge (not run). Anyone have this problem. Where you have installed the sensor? How to set the temperature gauge? thank you Quote
rubberneck Posted April 12, 2009 Report Posted April 12, 2009 Kinda like Volfan's but I had to make one fit an anti-vibe.... I like this set up. If i decide to put my vapor back on im going to steal this idea. :biggrin: Quote
banman350 Posted April 18, 2009 Report Posted April 18, 2009 I have a vapor trailtech. I have trouble with temp gauge (not run). Anyone have this problem. Where you have installed the sensor? How to set the temperature gauge? thank you i got one, ive sent it back once already and now the speed/distance stuff doesnt work and neither does the temp, the things junk after about 6 months to a year Quote
vulvafan537240 Posted April 25, 2009 Report Posted April 25, 2009 i got one, ive sent it back once already and now the speed/distance stuff doesnt work and neither does the temp, the things junk after about 6 months to a year ive had mine for a while now with no probs :shrug: Quote
