cearven1987 Posted December 11, 2008 Report Share Posted December 11, 2008 (edited) ive been having trouble geting my clutchs to adjust right i get them right then ill ride it for like 5 min then i wont have any clutch at all ive ordered a new clutch cable a new actuator and the screw you tighten and loosen the clutch so all i didnt get is the rod how often do they get wornout i should get the parts tomorrow but im kinda wondering if i should have got the rod Edited December 11, 2008 by cearven1987 Quote Link to comment Share on other sites More sharing options...
RUDEDAWG Posted December 11, 2008 Report Share Posted December 11, 2008 (edited) There is a ball bearing looking thing that goes in after you install the rod., goes between the rod and the adjustment screw, did you loose yours? Edited December 11, 2008 by RUDEDAWG Quote Link to comment Share on other sites More sharing options...
cearven1987 Posted December 11, 2008 Author Report Share Posted December 11, 2008 o sorry no mine still has it but i ordered a new one it was kinda weird when i took it apart the ball bearing was stuck to the adjuster screw it was really on there to i had a hell of a time getin them apart does that happen often the ball had 2 flat spots one where the rod is and one where it was stuck to the adjuster screw Quote Link to comment Share on other sites More sharing options...
RUDEDAWG Posted December 11, 2008 Report Share Posted December 11, 2008 Usually the ball welds itself to the rod, a pancake bearing is a perfect fix for that problem, get one, and you will never have that problem again! Quote Link to comment Share on other sites More sharing options...
cearven1987 Posted December 11, 2008 Author Report Share Posted December 11, 2008 whats a pancake bearing? Quote Link to comment Share on other sites More sharing options...
RUDEDAWG Posted December 11, 2008 Report Share Posted December 11, 2008 Check out farmandsandtoys.com they have a pic. of one, look under banshee clutch/transmission. very small price for a big piece of mind. :thumbsup: Quote Link to comment Share on other sites More sharing options...
cearven1987 Posted December 11, 2008 Author Report Share Posted December 11, 2008 thx ill check that out but does the rod ever really go bad Quote Link to comment Share on other sites More sharing options...
spurdy Posted December 11, 2008 Report Share Posted December 11, 2008 thx ill check that out but does the rod ever really go bad I have seen them get hot on the end next to the ball or weld to the ball. Other then that I don't think it can go bad. SP Quote Link to comment Share on other sites More sharing options...
cearven1987 Posted December 12, 2008 Author Report Share Posted December 12, 2008 well now i got another problem i changed out the actuator on the other end of the rod and havent put an hour on it and its messed up again do yall think that could of ben caused by the ball being welded to the adjuster or what would cause that? i changed it before i realized that the ball wes welded Quote Link to comment Share on other sites More sharing options...
