Interchangable parts from other yamies.
Blaster & Banshee axles interchange, easy way to gain 2" on a Blasty but you'd be goin' -2" the other way.
Banshee & YFZ450 front brake master cylinder and calipers are direct bolt-ons, YFZ450 lines will work even with +2 a-arms although the tee mount doesn't match up exactly it'll work. I'd bet Raptor and Warrior are the same, although single piston like Banshee and not 2-piston like the YFZ.
There's the Blaster pegs thing too, 2" back and a little lower, I think Raptor pegs are similar. Oh hey intakes and crossover tubes/boost bottles interchange from Banshee to RZ350 along with a couple other items :happy:
huh? :huh:
He's talking about the brake calipers, the banshee, blaster, raptor, warrior all have single piston brake calipers, the yfz has dual piston calipers. I believe the stems interchange but they're different lengths, I think people were putting worrior or banshee stems on their blasters for + lengths. The spindles all interchange also I believe.... There's quite a bit that interchanges.
oh yah, duh.... caliper piston, was thinkin engine for some reason :shoothead:
some polaris quads have the same front bolt pattern
polaris, ha ha :yelrotflmao: the historically polar opposite of yamaha. not talkin about parts, just mentioning polaris made me think about how yamaha hasn't built a decent sled untill recently, and polaris just needed to stick to sno-go's. but recently, anything goes- a little off subject
old school tri-Z three wheeler axle is the same as a banshee also. Also the warrior rear brake disc will fit a banshee and OEM price is about half of the cost of a banshee one.
Also in 04 when I built a new bike I wanted to buy a new factory banshee frame. this is when i worked at the dealership, a stock 04 frame was like $780 retail, I was diggin through the computer and found that a 04' limited edition frame which is exactly the same except black instead of silver was less than $500 retail. I am sure yamaha caught this eventually and you would have to know your dealership guys really well for them to do something like this but it made me laugh.
Also I needed a CDI after doing some digging again (the previous thing tought me) I found that you could by the GYTR performance CDI for like $100 cheaper than the stock unit. I have the GYTR unit now and have swapped it on several bikes and can be damned if I can tell any difference, but it was cheaper, smaller and mounts better (comes with a bracket). Plus it comes with a GYTR sticker on it...that scares the shit out of the guy you are linning up with....lol
I also came across a small aluminum kickstarter, a friend foud out on the sand it got threw into a box of misc. parts I ran across it while building my last bike and did some comparing to find out that it fit a banshee knuckle perfect, it is trick looking follows the clutch case lines real well and is kinda a 1 off on my bike, no clue what it is off of, I had it polished and the knuckle chromed, I will take a pic mayby somebody can recognise what it is off of.
Edited by Wiz
