peterlocal22 Posted December 8, 2008 Report Share Posted December 8, 2008 i have a moose thumb throttle and like it alot better than stock but still kind of stiff im going to buy the little ext. for it next Quote Link to comment Share on other sites More sharing options...
BUILDER Posted December 9, 2008 Report Share Posted December 9, 2008 i have a moose thumb throttle and like it alot better than stock but still kind of stiffim going to buy the little ext. for it next Just add a twist throttle. i have lots of trouble with my hands and a twist throttle made it much better for me. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted December 9, 2008 Report Share Posted December 9, 2008 am really sick of this stock thumb throttle.. after some time of riding my thumb becomes numb. isn't there any solution to make that thumb lighter ? smoother ? easier ? Thanks. Dan Wade from Patriot Racing taught me a trick. Use an older model honda thumb throttle. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted December 9, 2008 Report Share Posted December 9, 2008 Check the routing on your cable to the carbs...it could be pinched, etc. I don't think the single carb setup is worth it....unless you ride tight trails. Snop, I tried an older 400EX throttle (I had to grind the HONDA off the top and polish the cover....) and I didn't notice any difference. Not a great idea to cut loops off the carbs. Lightly sand the outer edge of the spring evenly, top to bottom. When you cut loops off the spring, the initial pull is easier, but the 1/2 to WOT is the same...it feels tougher though because the initial pull was so much easier. Clean up the spring with a nice fine scothbrite pad so you don't have any sharp/rough edges. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 9, 2008 Report Share Posted December 9, 2008 Check the routing on your cable to the carbs...it could be pinched, etc.I don't think the single carb setup is worth it....unless you ride tight trails. Snop, I tried an older 400EX throttle (I had to grind the HONDA off the top and polish the cover....) and I didn't notice any difference. i would've just stamped "sucks ass" under it, or someting along those lines :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 9, 2008 Report Share Posted December 9, 2008 anyone ever try sno-go throttle? Quote Link to comment Share on other sites More sharing options...
cearven1987 Posted December 10, 2008 Report Share Posted December 10, 2008 im not sure what kind of carbs u have but fast sells some lighter springs for some Quote Link to comment Share on other sites More sharing options...
