figster Posted December 6, 2008 Report Share Posted December 6, 2008 i need help fast, i replaced the stock pipes on my banshee an also the jetts and needles. i left the stock pilot jet , replaced the the main with 280 and the needles with dno 304, it runs and starts pretty good but it wouldn't stop leaking gas from my left carb. what can be wrong ? need help Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted December 6, 2008 Report Share Posted December 6, 2008 floats stuck, or dirt on the needle seat. Quote Link to comment Share on other sites More sharing options...
Paddleboy Posted December 6, 2008 Report Share Posted December 6, 2008 i agree the float is stuck. try taping it with a screw driver or if that dont work take the bowl off and clean it Quote Link to comment Share on other sites More sharing options...
figster Posted December 6, 2008 Author Report Share Posted December 6, 2008 i agree the float is stuck. try taping it with a screw driver or if that dont work take the bowl off and clean it i did that already and it is still leaking Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted December 7, 2008 Report Share Posted December 7, 2008 i did that already and it is still leaking Then the float needs adjusted. Take the bowl back off, and bend the tab up, that the needle hooks onto. Quote Link to comment Share on other sites More sharing options...
