oldskoolracer Posted December 4, 2008 Report Share Posted December 4, 2008 Do you have to have a speacial brand of this if you change out the stock lines? i know i've seen it at my local true value store but i'm unsure if it will be wrong for the setup any suggestions? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 5, 2008 Report Share Posted December 5, 2008 The local hard ware store more than likley doesnt sell the right stuff. It isnt rated for the temperature. When your banshee warms up the hoses get super soft and flemsy. There is a reason why the real WOCO clear radiator hose kit is 100 bucks. It isn just relabled braded hose like the cheap ebay kits you see. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted December 5, 2008 Report Share Posted December 5, 2008 The local hard ware store more than likley doesnt sell the right stuff. It isnt rated for the temperature. When your banshee warms up the hoses get super soft and flemsy. There is a reason why the real WOCO clear radiator hose kit is 100 bucks. It isn just relabled braded hose like the cheap ebay kits you see. +1. Check the temp rating. I heard the clear kits crack a lot or something? I've always been told not to use 'em. Quote Link to comment Share on other sites More sharing options...
okbasspro Posted December 5, 2008 Report Share Posted December 5, 2008 I run hose form the local hardware store. I have not had any problem with them they do not get soft enough to fold over and kink it only cost about 5 bucks so I was willing to try it I have been running them for a few months now. Jeff Quote Link to comment Share on other sites More sharing options...
oldskoolracer Posted December 5, 2008 Author Report Share Posted December 5, 2008 MIGHT HAVE TO TRY IT Quote Link to comment Share on other sites More sharing options...
Wiz Posted December 8, 2008 Report Share Posted December 8, 2008 I had a set of those WOCO hoses....cracked and leaked in no time....good service from where I bought them from (not WOCO) they got me another set after calling WOCO and complaining, installed new set...they cracked and leaked.....went back to stock hoses...have been thinking about the hoses at Home Depot (clear braided) I have a friend that runs it and it has worked for him for quite some time. looks good on his blue bike with engine ice in them.... Quote Link to comment Share on other sites More sharing options...
#1banshee Posted December 8, 2008 Report Share Posted December 8, 2008 so If i go to homedepot and look what section do I go to? Quote Link to comment Share on other sites More sharing options...
ban99 Posted December 8, 2008 Report Share Posted December 8, 2008 so If i go to homedepot and look what section do I go to? plumbing Quote Link to comment Share on other sites More sharing options...
#1banshee Posted December 8, 2008 Report Share Posted December 8, 2008 plumbing aight good look... Quote Link to comment Share on other sites More sharing options...
#1banshee Posted December 9, 2008 Report Share Posted December 9, 2008 I got the clear hose whats better the clear or the braided one? or it dont make a diff Quote Link to comment Share on other sites More sharing options...
Wiz Posted December 9, 2008 Report Share Posted December 9, 2008 the braided hose is better it will not swell as much as the standard clear, and it is made for hot water, the standard clear is a low pressure no heat hose. Quote Link to comment Share on other sites More sharing options...
#1banshee Posted December 9, 2008 Report Share Posted December 9, 2008 (edited) aighttt i will go back today and exchange it with the other hose.. Edited December 9, 2008 by #1banshee Quote Link to comment Share on other sites More sharing options...
Wiz Posted December 10, 2008 Report Share Posted December 10, 2008 okbasspro, are those Sand Gecko tires on your banshee? does it hook up with those tires? looks like you are running alot of motor and not alot of tire? Quote Link to comment Share on other sites More sharing options...
