BUILDER Posted December 8, 2008 Report Share Posted December 8, 2008 alright i just stripped my carbs right down and cleaned them and sync'd them when i put them back together. i looked at the pilot jets and it had 2.8 written on it. is that a good size? it is still bogging out from an idle and will not start when it is cold and runs fine when its warm(except from an idle. i need to know what size pilot jet to run and should i try a set of 280 jets? I am not sure what a 2.8 pilot jet is i have never seen that on a pilot maybe someone esle can tell you what that is. You should have a 27.5 pilot jet to start out and work from there. Putting a bigger main jet in will not help your starting problem your pilot is were your starting problem is. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 8, 2008 Report Share Posted December 8, 2008 I am not sure what a 2.8 pilot jet is i have never seen that on a pilot maybe someone esle can tell you what that is. You should have a 27.5 pilot jet to start out and work from there. Putting a bigger main jet in will not help your starting problem your pilot is were your starting problem is. ditto. 2.8? not sure what that is, but if snow is flyin, then you need at least 27.5 and 280's prolly 300's, but gotta get that pilot richened up. you know it's lean, but not what size, so if you start with a known size, at least you know where to go from there. Quote Link to comment Share on other sites More sharing options...
