How To Tell
#1banshee
What size a carb is? I gota 2into1 and I want to find out what size the carb is.. Near the bowl it says PJ and then numbers... How do I go about seeing what size this carb is.. Thanks
Post up the #'s on it and mabey a pic of it, but i would say its a 34.
Started to really tear it down to clean it all and get it ready for the lone star equipment!!
kinda blurry this is the port work...next 1 is better
The hose that's under the water housing that go's into the case what is that for?
I found it hooked up to nothing basicly laying there...Does this need to be hooked up
to something? Also I bought the billet water impeller does this whole case have to come
off to replace that? Has anyone done it b4?
The carbs I was wondering about 34's?
this should work with my setup? new crank with hot rods long rod kit on it wiseco pistons that are 1mm bigger bore port and polished by sand tech racing of nevada cool heads with 19cc domes toomey t-5 pipes vforce 3's.... EDIT and +4 timing...
Edited by #1banshee
Clymers is a repair manual.
It will tell you how to fix things (step by step) like the water pump.
Also has pretty good pics to show you what they are talking about.
It is a really good help.
That single carb may not be enough volume depending on your porting.
Check with the guy doing the port work. He should be able to tell you how
much carb you need to compliment his work.
