Installing head/domes/timing plate...
Tomorrow I'm installing my Pro Design Head, 21cc domes, and a Chariot Timing plate (+4.)
I was wondering what kind of troubles you guys ran into, any tips you may have, etc.
I am NOT asking how to install anything. I have all that information.
I just want to know what to expect, what kinds of problems you guys might of had, etc...
This will be the furthest I've broken my bike down to on my own, so I'm a bit weary and want to be as prepared as I can.
  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
the worst part is going to be taking the stock head studs out. those PD are a pain in the ass since you have to dick with that shit. take your time, do it right. use some yamabond on the threads when you install the new ones. make sure you have some bearing grease or something to hold the o rings in place, otherwise sometimes theyll move around.
as for the timing plate.. youre gonna need the flywheel puller. its a simple swap. just make sure your woodruff key goes back in correctly.
ive never snapped off a stud and ive had some pretty old motors. if yours is a 2005 you shouldnt have an issue.
Yeah, what he said. ^^^^
Also, never had to heat the cylinder either.
When i did my rebuild i didnt replace the studs is that bad or is that just a standard procedure you guys do? They looked fine threads still in good shape and no bends or anything.
They are talking about replacing the stock studs with the studs provided from Pro Design. Unless you install a Pro Design head there is no reason to replace the studs.
9 came out with vice grips, 1 is sitting there and still won't come out...
Threads are to destroyed to double nut (didn't have a 12mm wrench anyways), the propane torch I tried to use was from like 1970 and caught fire and almost blew up in my garage, but I played fireman.
:evil:
:evil:
go to the parts store, ask for freeze-off. use it just on the stud
