aftermarket heads
crazycanuck
Any head the uses a prodesign dome, like noss head. i think anything under a 19 or 20mm head you want to run a high octane fuel. it depends on your starting compression. Im not sure about the horse power gain but i think its between 0 and 10. :shrug:
Chevshee
I recommend the Noss heads for three reasons:
1) Quality and customer service is second to none
2) Uses stock head studs
3) He is a sponsor of this site, help support those who support us
As for your domes, you will want to go with 20cc domes to run pumpgas at your elevation, 19cc to run 100octane and 18cc for 110 octane
The peak hp gain is minimal with higher compression, but you will have a substantial increase in low to mid hp/torque.
last post sounds about right I am at around 2000 and am running 19cc with 105 and it rips. lots of companies make after market heads but make sure yo know what you are after! I have a vito's hemi head and its great but if I want to go past a 66mm bore you have to upgrade
